Greddy Emanage Blue
Greddy Emanage Blue
I have a Greddy Emanage Blue I'm selling.
Tuned for NA - headers-back exhaust and full intake at UMS Tuning in Tempe, AZ.
Been used for only 6 months or so. I'm changing engine management systems.
Included is IGNITION HARNESS, and INJECTOR HARNESS along with the MAIN HARNESS.
Looking for $250.
-I don't have any pictures up yet as its still installed in my car, but I can take them and post them for anyone who is interested. Looks brand new.
I know I don't have any iTrader on here, but my name is Tollboothwilley on g35driver.com and my350z.com and you can check out my iTrader there as well.
Looking for $250.
It most definetly can. You just need the ignition harness...included in the sale. The injector harness (included) allows you to add fuel to a 16x16 map instead of just using the dials. This way everything can be tuned much better.
I had this tuned to my car with headers, HFC, full exhaust with full intake mods.
Good map to start with.
Yes it can control VTC.
In fact, many honda guys have used it because it controls their VTEC
I'm located in SLC, UT.
Unit has been used for only about 6 months.
hmm interesting, will ask around to confirm, didnt belive it advanced only retarded timing. was this tune on a vq35de or vq30de?? 350 or maxima? who as it tuned by? any idea what the tune info is as far as timing?
VQ35DE. You can only advance timing on the emanage when you have the IGNITION wire set. It allows you full control over timing. The INJECTOR harness allows you to control fuel supply. You can use the dials to adjust for size of injectors and then use the INJECTOR harness to fine tune.
I had it tuned on my G35 at UMS tuning in Tempe, AZ by Tony. Very very good tuner. My G35 sedan uses the 2002/2003 Maxima ECU which I believe is the A33.
As far as what timing/fuel adjustments...I believe its around 4 or 5% added fuel + progressively more timing at redline...between 3-5.5* from 3000 rpms up.
tarun900
19
Dec 20, 2021 06:57 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
