Forced Induction Sell your turbos, supercharger, nitrous, and related items here
Feed and Downpipe Forsale 700.00
Old Oct 4, 2010 | 11:56 AM
t6378tp's Avatar
Turbo 3.5
Complete forward feed and downpipe - 950.00
Ok, I am selling the feed and downpipe right off my car, price is 950.00 for both. The feedpipe is starts out as 2inch to 2.25 to 2.5 into a T4 flange with a 44mm v-band tial wg flange. The pipe has been sprayed, wrapped and sprayed again and seperated into two peices by a 2.25inch v-band to make it easy to install and remove. The turbo faces the back of the drivers side headlight. The downpipe is 3inches all the way into catback and uses the stock hangers and will bolt up to a stock catback. The downpipe is in two pieces and connects to the turbo with a 3inch v-band and is seperated right before the tranny and connected the 2nd half with another 3inch v-band. The downpipe goes under the small part of the tranny to save ground clearance then crosses over to the passanger side and into a 3inch flex, finally into the catback with a O2 bung for a wideband already welded in.
The kit spools quick has not seen snow and does not leak, willing to include the turbo for an addition fee. You can read more about the setup here : http://forums.maxima.org/forced-indu...rbo-build.html
Also here are some pic's :
Old Oct 9, 2010 | 09:17 AM
t6378tp's Avatar
Turbo 3.5
bump for new item
aw11power
Oct 10, 2021 04:57 AM
Cotozic
Jun 28, 2017 08:01 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
homewrecker
Aug 24, 2015 08:56 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
