Forced Induction Sell your turbos, supercharger, nitrous, and related items here
CA FS: custom water to air aftercooler/intercooler system
Old Aug 12, 2014 | 02:00 AM
Wassup boosted brothers
For sale is a custom water to air aftercooler system. Can be utilized for both supercharged and turbocharged applications. It was originally owned by furbiss112, then Slimer, then me.
Currently, only Ptatohed and me have water to air aftercooler systems. I30krab did/does too, but he hasn't posted in ages so....Mhadford did too, but he's parting out currently. Join me and Ptatohed, and we can be the 3 water to air musketeers.
It is known that a car will gain 1% to 2% total output power for every 11 degrees cooler intake air charge, having a colder intake charge is very important. At idle and crusing, the temperature delta is 20 to 30 degrees. At WOT, I've seen a 60 degree delta. With fresh ice, I've seen a 75 degree delta. This would be best for 1/4 mile use, but is fine for street use too. Drain the system, fill it with cold water and ice, you're ready for a sweet dyno pull or a drag strip race.
I never got around to installing it in one of my other supercharged Maximas, so I don't have any installed high res pictures. The installed poor quality pictures are all I could find from when Slimer and furbiss112 owned it. When you see it as raw aluminum, that's when furbiss112 owned it. Slimer then painted it black, and I've painted it black in some areas too for touch-up.
Custom air-to-water aftercooler with front heat exchanger that mounts to the lower radiator support and water pump. You'll need to take your Stillen IAT sensor adapter and insert and seal with Hi-temp RTV. The black water line hoses should probably be replaced simply due to their age. I will include them in the sale so you have a go by so you have a reference for length, size etc.
Parts included:
aftercooler box
water reservoir
heat exchanger
water pump
'S' shaped charge pipe
charge pipe with TurboXS BOV
The inlet and outlet size of the aftercooler is 2.5", the same size as Stillen's piping on their supercharger kit.
Price: $550 shipped anywhere in the contiguous US. The price may seem like a lot, and it is, but FWIW I spent nearly four times this amount on my PWR aftercooler system on my beast that is putting down 383hp. If you don't want the TurboXS BOV and/or the pipe that goes with it, let me know and I can drop the price.
Thanks,
Wiz
Old Aug 12, 2014 | 02:05 AM
This is how it looks as a system
Now I'll show individual pics
The aftercooler
IAT sensor goes here
Old Aug 12, 2014 | 02:07 AM
reservoir/access port (in blue)
Drain
Old Aug 12, 2014 | 02:08 AM
water pump which mounts to side of aftercooler box
Old Aug 12, 2014 | 02:12 AM
Heat exchanger
Misc pictures
Old Aug 12, 2014 | 02:16 AM
Last but not least some old installed pics...
On the right, you can see the water pump with bracket peeking out...
Old Aug 12, 2014 | 09:13 AM
Quickywd01's Avatar
Mhadford's went to me when he parted out. Water to air is king! GLWS!
Old Aug 12, 2014 | 12:58 PM
Ahhh. so you snagged it. Nice! Looking forward to your build thread.
Added more info to post #1.
Old Sep 7, 2014 | 02:56 PM
Bump.
Price drop.
Old Sep 28, 2014 | 01:46 PM
furbiss112's Avatar
This is a great setup. I know since I had it custom made. I ran 13.2 @ 106mph on 5 psi of boost, street tires and full throttle after 40 mph. I see you used pictures from my cadomain as well. Good luck with sale.
Ferhan
Old Oct 5, 2014 | 02:19 AM
Ferhan
Thanks Ferhan, and thanks for posting your impressive time slip!
Old Oct 9, 2014 | 02:48 AM
Price dropped!
Old Nov 25, 2014 | 01:47 AM
Accepting reasonable offers...
Old Jan 14, 2015 | 06:19 AM
New year, new price. First posted updated with new price.
Any lower, I may just have to throw this up on Ebay
Old Jan 16, 2015 | 09:16 PM
AlexxSCM's Avatar
how much picked up
Old Jan 18, 2015 | 04:08 AM
Originally Posted by alexx0108
how much picked up
PM sent. LMK
Old Jan 18, 2015 | 05:26 PM
AlexxSCM's Avatar
text me so we can go over fitment on a dek.
Old Feb 12, 2015 | 03:39 PM
Quickywd01's Avatar
Buy it! You're going to be jealous you didn't when you see mine.
Old Jun 8, 2015 | 12:13 AM
Beginning of Summer bump. No better way to cool down hot boost than with an aftercooler setup where you can drop ice into it
Old Aug 2, 2015 | 09:24 PM
Bump. Reasonable offers will be entertained. Thanks.
Old Jul 26, 2016 | 08:18 AM
Bump.
Old Aug 17, 2016 | 05:15 PM
Bump. This is perfect for those hot summer days at the track.
Old Nov 29, 2016 | 11:07 PM
Bump for cooler Booooooost!
Smackasmith
Feb 1, 2016 12:40 AM
97_GXE
20
Sep 17, 2015 08:12 PM
carid
Sep 9, 2015 05:06 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
