Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
Jack Stand End Cap
Old Feb 7, 2006 | 04:30 PM
2002 Maxima SE's Avatar
Jack Stand End Cap
Is there some sort of end cap I can get for my jack stand so that it fits the grooves of the unibody jack point? I usually just put the "V" of the jackstand there, but it seems like there would be a better solution.
Old Feb 7, 2006 | 07:17 PM
nismos14's Avatar
§è~® f®ÈÄk
Yes, but I think they are only sold with the jack stands and only certain types come with the sliders.
Old Feb 7, 2006 | 08:44 PM
Puppetmaster's Avatar
You might be able to get em here, if these are what you're referring to:
http://www.eastwoodco.com/shopping/p...d=jack+adapter
Old Feb 7, 2006 | 08:48 PM
I realize now that you said something for the stands and not for the jack itself.... I'll let ya know if I find anything, because I was actually just thinking about these adaptors today as I was under the car.
Old Feb 7, 2006 | 08:57 PM
job12345's Avatar
Where is the proper place to position the jack stands
Before I destroy my car, are there any pictures in this forum that will show me where to properly position my jack stands?
Old Feb 7, 2006 | 09:00 PM
Saved this from when Ben posted it...
Old Feb 7, 2006 | 09:11 PM
job12345's Avatar
Thanks, Puppetmaster.
Old Feb 8, 2006 | 05:42 PM
Yeah, I could swear I saw these before for the jack stand. For the jack I use a rubber hockey puck.
Old Feb 9, 2006 | 07:44 AM
BigFly_2K2SE's Avatar
I am subscribing to this thread because I would also be very interested in such an adaptor.
Please explain to me how the hockey puck helps you with the jack (not insulting, just curious). Is the reasoning that it is round so fits nicely inside the jack "cup" and the result is that the weight on the pinch-weld is distributed evenly across the diameter of the puck?
Currently, I have a square piece of wood that fits inside the jack stand "cup" and cut a notch through the middle where I fit the pinch weld inside. It seems to work okay except that the wood is starting to get pretty bent out of shape from the weight of the car.
Old Feb 9, 2006 | 03:34 PM
Yes, the puck distributes the weight same as a piece of wood.
Old Feb 12, 2006 | 07:50 AM
This is pretty close:
http://store.summitracing.com/defaul...2&autoview=sku
Old May 7, 2006 | 10:15 AM
Slaine's Avatar
Embarrassing newbie question here, but when I attempt to jack up my car using a hydraulic jack located at the jack point at the front of the car (as seen in the picture shown above), it won't lift the car high enough for me to position jack stands in the notches just behind the front wheel. Is there another point on each side of the car where I can use the jack to lift the car enough to place jack stands in the appropriate spot and not screw the car up royally?
Old May 7, 2006 | 05:29 PM
Zero Deuce SE's Avatar
What is the maximum lifting height of your jack? You might just need a different jack that will lift higher than the one you use.
Old May 7, 2006 | 05:44 PM
This seems like it would work as long as the notches are deep enough.
http://www.autobody101.com/shop/10362.html
Old May 7, 2006 | 06:22 PM
I researched the safety stand attachments listed in the FSm at the Kent Moore website and there was no part number in the Nissan to KM cross reference. The Nissan number is LM4519-0000.
https://www.nissan-techinfo.com/niss...p/Tool_Cat.pdf
Old May 8, 2006 | 06:10 PM
I emailed SPX/Kent Moore yesterday asking them about the attachments listed in Nissan's service manual and they told me that they did not make them and didn't know of anybody that does. Somebody could probably make some good money if they produced those suckers.
Old May 9, 2006 | 07:05 AM
Thanks for the legwork Zero. It sure would be nice to have something like this more easily available..........as I said above, my grooved pieces of wood are getting bent out of shape.
Old May 9, 2006 | 02:19 PM
You're welcome. I'm not giving up yet though. I will eventually find or make something to go on top of my jackstands.
Old Feb 25, 2009 | 01:01 PM
diverdown3's Avatar
Ressurecting an old, but relevent thread.
Posting pics of a jack stand head I designed and fabricated to accomidate welded unibody seams interfering with Maxima factory jack stand support points. If members are interested, I can provide diagrams, but the design is simple and straight-forward.
My paint is lousy, but it's a jack stand, right? The excess rubber pads will be cut off once the adhesive dries thoroughly.
Comments welcome.
Old Feb 25, 2009 | 01:19 PM
diverdown3's Avatar
Continued...
Old Feb 25, 2009 | 06:22 PM
Posted a comment in your 5th Gen thread, but moving this to the Garage forum, where it belongs. Thanks.
Old Feb 25, 2009 | 06:50 PM
diverdown3's Avatar
Realized that after posting. Sorry for the housekeeping chore. Unintentional.
Old Feb 25, 2009 | 06:51 PM
No, totally not your fault. This thread is older than the Garage subforum, so I'm glad it was brought back.
Old Feb 25, 2009 | 07:35 PM
ThurzNite's Avatar
Where the block touches the body, what is that made of?
Dr J
Old Feb 25, 2009 | 08:20 PM
diverdown3's Avatar
Dr J
Rubber. I figure if people have trouble sourcing beefy rubber stock, they could get resourceful and pick up some used truck flaps from a truck service center or use a sawzall on an old tire.
Miket2006
Mar 1, 2021 03:55 AM
05RLS2
Apr 14, 2016 11:49 AM
BobTX10
Oct 7, 2015 08:43 AM
