Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
Advice on a timing light?
Old Feb 12, 2008 | 06:37 AM
grey99max's Avatar
LandShark has Cosworth
Do you use a timing light on your Maxima? And if so, what manufacturer and how do you hook it up?
There are lots of inductive timing lights out there, but we can't just clamp onto the spark plug wire.... There must be some that trigger on the Maxima.
Old Feb 12, 2008 | 01:13 PM
505max94se's Avatar
I just got one from AZ and put the clamp around the #1 cylinder wire, before the coil and it worked fine. According to the fsm, you're supposed to use a plug wire extension, so the timing light is getting a reading after the coil.
Old Feb 12, 2008 | 01:29 PM
grey99max's Avatar
Thanks - I just got time to look at the FSM and it shows using an induction proble clamped around the timing loop built into the wiring harness, as well as how to remove the #1 coil and extend it so a clamp-on will work.
That's what I needed...
Old Feb 12, 2008 | 06:14 PM
choray911's Avatar
The Crazy Azz Cracka
What in the world do you need one for?
Old Feb 12, 2008 | 06:49 PM
grey99max's Avatar
Well - I want the timing light to check changes that Datascan can make in ignition advance and retarding. That program can supposedly do that. I want to see.
I also want to see the actual ignition timing match what the ECU claims it's doing. I have read mentions of changing the positions of cam and crank sensors causing changes in ignition advance - again, I want to see it.
Old Feb 27, 2008 | 09:51 PM
OH6 G35's Avatar
SnapOn makes a really great unit...but it's really expensive!!
doctorpullit
Aug 20, 2015 05:15 PM
carlosvq30
Aug 17, 2015 11:32 AM
beboski
Aug 16, 2015 05:23 PM
Superbform
Aug 11, 2015 08:10 PM
yat70458
Aug 3, 2015 01:16 PM
