Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
Welder, cut off wheel...
Old Apr 24, 2008 | 08:31 PM
92gxe/cg2's Avatar
Hey guys, i have a 3rd gen maxima and it has some rust since i live in the rust belt and all that bad stuff... I was thinking of maybe buying one of those cheap welders and cutoff wheels to experiment with some rust work. Things like cutting of the edges of the wheel well or back of the rocker panel, and welding in some old sheetmetal and then bondo-ing and painting. I saw some cheap welders on harbor freight taht i heard would work but i am unsure.
http://www.harborfreight.com/cpi/cta...emnumber=94056
Theres a couple relatively cheap welders, but will they even do the job?
What about this as a cut off wheel, will it work?
http://www.harborfreight.com/cpi/cta...emnumber=92880
Any help is appreciated, Im am clueless in this area, but everyones gotta start somewhere.
Old Apr 24, 2008 | 09:04 PM
Jeff92se's Avatar
I'm needing a caw
Flux core welders will put down a real messy/smokey welder. At least get a cheap unit that uses gas.
That dremel thing won't cut it. A cheap 4" grinder with the right cut off wheels would be a much better tool. You can cut, grind, sand etc... with it.
4' grinder.
http://www.harborfreight.com/cpi/cta...emnumber=91223
I didn't see any 100v mig welders on there. Odd
Old Apr 24, 2008 | 10:00 PM
92gxe/cg2's Avatar
Alright that looks good. I just was told i should go for a MIG welder. Whats this gas for? I see some without and some with?
Old Apr 26, 2008 | 06:59 PM
BenStoked's Avatar
Jesus was a Zombie.
its a shielding gas; check this out,
http://en.wikipedia.org/wiki/Shielding_gas
explains it alot better than i could try.
James92SE
142
Jan 2, 2024 09:23 AM
magiconthetire
Oct 26, 2015 09:03 PM
RealityCheck
Oct 2, 2015 06:34 PM
Taino14
Sep 24, 2015 02:51 PM
