Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
Is it Safe to Run a Oil Lubed Electric Air Compressor in Winter Conditions?
Old Feb 15, 2009 | 12:54 AM
1993-VG30E-GXE's Avatar
Just wondering if this will rust the internals - sucking in cold air from outside into the machine. Or should I situate the unit inside and run mega length hoses?
Old Feb 15, 2009 | 07:04 AM
VQP0WER's Avatar
It will be fine. I sometimes spray fogging oil into the cylinder beforehand.
Old Feb 28, 2009 | 09:08 PM
HM_Motorsports's Avatar
Mine is in my unheated garage this winter and I've actually noticed less condensation than in the summer. I wouldn't worry about it, just drain it regularly. Fogging oil probably isn't a bad idea either. Good idea! never thought of that.
Old Mar 31, 2009 | 07:47 PM
maxified's Avatar
I used mine and noticed that it was labouring a bit, and it shut down before I could get to it. Took it inside and no problems. But then again, I was using it in -15 deg c weather, with a windchill of around -24 deg...
Old Apr 1, 2009 | 04:34 PM
Interesting - thanks guys. I ended up just putting together a 65 foot 1/2" hose and then just run the machine in the basement indoors, and pull out the hose when I needed to use it. I put an inline filter 3/4 way down the line (it was really cheap but it does seem to catch some water pretty good), then a 15 foot hose that goes into the tool.
maxinout93
Oct 27, 2015 01:29 PM
iflexsteel
Sep 15, 2015 03:37 AM
homeyclaus
Sep 3, 2015 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
