Garage and Workshop This forum is for discussions of what goes on in the garage - "the tools, the techniques, the tricks" ...or something like that. DO NOT POST QUESTIONS ABOUT YOUR CAR HERE.
Blow torch
Old Mar 10, 2010 | 11:03 AM
NYC TAR's Avatar
Blow torch
what kind of blow torch do your guy use or recommend?
working on maxima on used to be fun, but all the nut and bolt are rusted, due to the the Northeast winter. Ever time I either snap an bolt, strip. or take to the mechanics for him to do (heat -cool methods), that is getting costly.
Does those plumbing torch work?
Old Mar 10, 2010 | 04:56 PM
Maxima_Joe's Avatar
4th Gen Parts King
Torch using mapp gas works good.
Old Mar 16, 2010 | 01:21 PM
Froggmann's Avatar
Personally I have a turbo torch that I use Mapp gas with. Works great and it's pretty easy to maneuver into tight places. Just look out for electrical in the area. Almost burnt down a Bronco that way.
Old Mar 17, 2010 | 06:02 AM
djfrestyl's Avatar
Suspension Yoda
I use a plumbing torch when I need to. Works fine.
Old Mar 17, 2010 | 07:00 PM
NYC TAR's Avatar
thanks, I grab an bernzomatic plumbing with mapp gas over at HD.
The flame is little huge, but it heat up very fast.
Originally, i was going to get a oxygen and mapp kit, but its going to cost a lot to operate .
Old Apr 8, 2010 | 03:23 PM
Negafen's Avatar
Is mapp hot enough to get a nice redhot glow to break corrosion? I've been using propane, and it has never helped me remove a stuck bolt.
Old Apr 9, 2010 | 08:39 AM
NYC TAR's Avatar
yes, mapp hot enough for that glowing hot red to break the corrosion in a few sec or min depending on bolt size. My torch kit came with mapp gas, but I want to try propane for general use. 9 dollars for mapp, 3 for propane, it's big difference.
But,make sure your torch head support mapp gas .
Old Apr 9, 2010 | 03:48 PM
Negafen's Avatar
I ran the gamut of other gas and had no idea mapp even existed haha. Well, thank god, it'll be worth the $9 to finally be able to get some fused bolts out.
Old Jun 24, 2010 | 03:33 PM
VEvolution's Avatar
I miss my VE
AZ has mag torches for around 18 bucks. Can't say the flame is that strong though.
Old Jan 17, 2011 | 02:13 PM
celicoupe's Avatar
I have oxy-acetylene which does anything I need it to as far as breaking bolts loose. The only draw back is that my hoses are only about 15 feet long. The initial cost is pretty high too. The secondary flame of MAPP is actually hotter than the secondary flame of oxy-acetylene so overall I waould say MAPP is the best.
Old Jan 17, 2011 | 02:22 PM
tonedef's Avatar
Uhhhhh, definitely oxy-acetylene or oxy-propylene... Propane, WTF???
Old Jan 17, 2011 | 02:23 PM
ampire's Avatar
My propane torch is pretty much worthless except it is useful for bolts that aren't completely stuck as it doesn't burn the surrounding area as bad as a more serious torch.
Old Jan 17, 2011 | 09:50 PM
I VIK I's Avatar
I have a oxy-acetylene, but I think that might be a bit of overkill, mapp might be the best bet with the bernzomatic.
Old Feb 6, 2011 | 04:19 PM
captain jack's Avatar
I use oxy-acetylene. You can weld and cut with it too. Great to have. Got mine on Craigs. Good luck.
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
RealityCheck
Oct 2, 2015 06:34 PM
Noela
Sep 26, 2015 08:22 AM
