JWT style 3.5 cams with adapters
Old Jul 27, 2008 | 07:00 PM
ghostmax301's Avatar
Well, I lost alot of oil due to a faulty oil psi switch and ended spinning a bearing so, new motor is going in. Cams are being sold.
If needed, i will sale the cam adapters with them so you can use them in a 3.0 or use the adapters for a 3.5swap.
its a 260/260 deg. duration with a 10.9mm lift
Selling for $500 obo with the adapters.(shipped)
Old Jul 27, 2008 | 07:20 PM
nismology's Avatar
The link is broken, mate.
Old Jul 27, 2008 | 11:07 PM
MODS, can you move this to the general FS section please.
Old Jul 27, 2008 | 11:12 PM
nismology's Avatar
Done. Even fixed the spelling.
Old Jul 28, 2008 | 09:52 AM
NiZMo1o1's Avatar
any pics ? JWT SYTLE ? so these are knock offs ?
Old Jul 28, 2008 | 11:42 AM
no pics as of yet. They are still in the motor. Going to start on the tear down today. But yes. they are the knock offs. I had a video of the idle but something happened to the link. Going to take another video today of the idle and post it up in about 3-5hours.
Old Jul 28, 2008 | 04:29 PM
NiZMo1o1's Avatar
are these just regrinds or acutal company that makes jwt knock offs ? Is there more specs on these?
Old Jul 28, 2008 | 04:57 PM
Deluboz is the company.
I believe Jime had a writeup of the satisfaction with these cams.
Spec
260 Degrees Duration / .428" (10.9MM) Lift (Intake Cam.Advanced 2 Degrees)
Cold Valve Lash .010-.013" on Intake & Exhaust
link to place where they were bought from
http://cgi.ebay.com/ebaymotors/JDM-P...QQcmdZViewItem
Old Jul 28, 2008 | 08:39 PM
NiZMo1o1's Avatar
PM'ed ya
Old Jul 28, 2008 | 10:11 PM
videos:
this is the noise coming from TC
exhaust note on cold idle
Old Jul 29, 2008 | 11:54 AM
anm6's Avatar
MMM Interested in how these cams are?
Old Jul 29, 2008 | 01:46 PM
grey99max's Avatar
LandShark has Cosworth
Spec
Hey ghost, I've got a set of those installed in my 3.5 '99, and they work very well. Were you able to bolt your cams in without changing any of the cam buckets? I was lucky with my install - everything within .001 " of spec. Used Stephen's cam adapters and no problems there.
Bad luck on your oil leak.
Old Jul 30, 2008 | 09:05 AM
nismology's Avatar
Can you confirm that the cams have not been damaged as a result of the oil pressure loss?
Old Jul 30, 2008 | 10:29 AM
stock cam buckets and yes nismology, I will pop the valve cover off when I get home and take pics. ill have the whole cam out by.........sat-sun as long as there is no rain
Old Jul 30, 2008 | 10:31 AM
Deckdout2's Avatar
Play with my balls
How do these cams fair with boosted applications? Is this lift/duration geared for a more N/A setup, or still good gains can be had with forced induction?
Old Jul 30, 2008 | 12:57 PM
!PrjctMax!'s Avatar
You must not have read all of it...
Old Aug 2, 2008 | 09:20 PM
bump bump bump
Old Aug 15, 2008 | 12:10 AM
VenoMax647's Avatar
gemmie two weeks
Old Aug 15, 2008 | 02:43 PM
Deckdout2's Avatar
Play with my balls
i'm interested in these, but i would like to have my question above answer prior to moving forward. thanks.
Old Aug 15, 2008 | 03:13 PM
nismology's Avatar
They are fine for boosted apps. Plenty of examples over on my350z. They are, after all, on the mild side of the spectrum no matter the application.
Old Aug 15, 2008 | 03:38 PM
Deckdout2's Avatar
Play with my balls
Preciate that. I'm not well versed in cams regarding specs and demographics. When I was looking a while back I knew different specs worked better (saw more gains) with specific applications, but couldn't recall that info (subscribed thread).
Will do more soul searching and advise decision. Thanks.
Old Aug 15, 2008 | 04:01 PM
nismology's Avatar
If you do decide to get a more aggressive grind, please be advised that the price will jump up by a few hundred (at the least) since these are knock-offs.
Old Aug 19, 2008 | 12:57 PM
$400obo shipped
bumpity bump bump..Ill give a few more weeks before I decide to keep them and install on my 3.5 swap
Old Aug 22, 2008 | 11:10 AM
Deckdout2's Avatar
Play with my balls
$400obo shipped
I wouldn't need to use the cam adapters if I'm installing these directly in a 3.5 correct? Only if they were going in a 3.0 and/or 3.5 swap?
I'm still debating back and forth, looking at this thread everyday, just haven't made up my mind yet. Sorry so slow.
Old Aug 24, 2008 | 11:10 AM
Deckdout2's Avatar
Play with my balls
Dun!
Old Aug 24, 2008 | 11:31 AM
nismology's Avatar
^^ Please make sure your installer verifies the valve clearance is correct before buttoning it up for good.
Congrats!
Old Aug 24, 2008 | 12:09 PM
Deckdout2's Avatar
Play with my balls
Congrats!
I will confirm.
Can't wait! Thanks sir.
Old Sep 2, 2008 | 06:29 PM
maxspeed88's Avatar
i need the adapters
Old Sep 10, 2008 | 07:46 PM
mowgli29's Avatar
Horizontally opposed.
I already have adapters...would you sell just the cams? if so, how much?
edit: wait...are these sold?
Old Sep 10, 2008 | 08:25 PM
NiZMo1o1's Avatar
I belive these are sold
Old Sep 11, 2008 | 05:50 AM
Deckdout2's Avatar
Play with my balls
yes, dey be sold.
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
magiconthetire
Oct 26, 2015 09:03 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
