F/S BNIB Greddy Emanage BLUE
Old Sep 22, 2008 | 12:44 PM
khantalha+'s Avatar
up for sale is a brand new, in box, Greddy Emanage Blue with the harness and manuals....
$265.00 shipped with priority Mail
Old Sep 22, 2008 | 01:51 PM
Scottyboi's Avatar
Trade you for a new super vortech fmu?
Old Sep 22, 2008 | 02:51 PM
khantalha+'s Avatar
^ pm replied
Old Sep 23, 2008 | 05:02 PM
khantalha+'s Avatar
price dropped.... OBO
Old Sep 26, 2008 | 10:44 PM
khantalha+'s Avatar
any one? make me an offer i mite take it... before it goes on ebay
Old Sep 28, 2008 | 02:14 PM
Donchoka's Avatar
is this still for sale?
Old Sep 28, 2008 | 06:15 PM
PhalC1's Avatar
What's the difference between this and the Emanage Ultimate
Old Sep 29, 2008 | 01:10 AM
khantalha+'s Avatar
Emanage blue
Greddy E-MANAGE - ENGINE CONTROL UNIT MANAGER
Greddy e-Manage is an inexpensive programmable fuel management system that allows you to properly tune your factory fuel system without having to change the entire factory ECU system to an expensive "stand-alone" unit. The e-Manage system is a universal "piggy-back" type unit which taps into most Japanese factory ECU wiring, by utilizing the existing sensors. Basic functions will allow the user to slightly alter factory injector duty-cycle (± 20% at 5 preset RPM points) by intercepting and altering airflow or MAP sensor signals. For Honda VTEC cars you can adjust the VTEC shift point. Additional features are built into the system but are only accessible through the use of the e0-1 programmer or our PC-Windows based "e-Manage Support Tool" communication software (Please see our Authorized GReddy Support Dealers for more information). There is a 16x16 airflow adjustment map, larger main injector correction adjustment, upgrade air flow meter adjustment, boost limiter cut, anti-engine stall, VTEC-fuel adjustment, real-time map trace, real-time display, real-time communication and basic Data-logging. With the use of our "Optional Injector Harness" and the software, the unit has the ability to control an additional 16x16 injector duty cycle map and the controls for adding up to 2 additional sub-injectors. If the "Optional Ignition Harness" and the software are used the unit has the ability to control a 16x16 ignition timing map. All of the above maps can also be map-traced in real-time as well. If the factory range of map or airflow meter is surpassed, you can incorporate our "Optional GReddy Pressure Sensor and Pressure Harness" to set larger scales of adjustment. All installation and tuning should only be made by a trained technician with proper air/fuel monitoring tools. (Some functions may not be compatible with some applications.)
Old Sep 29, 2008 | 01:12 AM
khantalha+'s Avatar
Emanage Ultimate
The GReddy e-manage Ultimate is as close to a stand-alone management system as you can get while maintaining the best features of a "piggy-back" engine management; an economical price, the usage of existing sensors, the ability to easily alter factory settings and not having to tune from scratch. But unlike the original e-manage, the Ultimate is more refined, requiring specific application usage (which we are constantly adding application updates that you can download FREE via greddy.com, Tech WebPages.) The benefit of this is, the included PC-based USB "Ultimate Support Tool" allows for even finer tuning capabilities, improved flexibility in fuel & ignition control and adds impressive data-logging qualities to make tuning quicker and easier. The increased number of input and output ports of the Ultimate, along with new built-in adapters add many new options to the unit. In addition to standard e-manage airflow-based adjustments, the Ultimate version includes new and upgraded features. The Parameter Set-up, tab menu format of the Ultimate has improved direct Map control for adding and subtracting Fuel and Ignition. The ability to switch between 2 preset tuning Maps (i.e. Street or Race program) via externally mounted toggle switches. There are Maps for Individual cylinder adjustment for both Fuel and Ignition. There are also options to convert injection and ignition systems (i.e. group or sequential injection and group or individual fire ignition.) An Airflow Output Map option even allows for airflow meter elimination. And when used with a wideband A/F Meter, the Air Fuel Target Map can self-tune an Injector base tuning Map, to speed up initial tuning. There are also built-in Boost, Rev and Speed Limiter-Cut features. To create super smooth operation, there are various fine tuning Correction Maps to adjust for Throttle Acceleration, Vehicle Speed, Water Temp, Intake Temp, Auto Trans Shift, Anti Engine Stall, and Idle. To further aid in tuning, e-manage Ultimate’s improved integrated Monitoring, Map Tracing and Datalogging features far exceed any other piggyback controller on the market. Even when not connected to the software, 8 channels of datalogging (at 20msec intervals) can be recorded and stored to be reviewed later. With the Support Tool connected, over 30 channels can be covered. Other new features include: Improved RPM recognition, Warning Settings, Password Protection for individual tuning Maps, NVCS (Nissan), VTEC (Honda), O2 Feed-back, Clean Fouled Plugs, and numerous others in future updates. Ideal for optimizing and fine-tuning for performance products like Exhaust, Air Intake, Intercoolers, Boost Controllers, and Turbochargers, the e-manage Ultimate fills the gaps between conventional piggyback and expensive stand-alone engine managements. All installation and tuning should only be made by a trained technician with proper air/fuel monitoring tools. (Some or all functions may not be compatible with some applications.)
Old Oct 14, 2008 | 10:48 PM
khantalha+'s Avatar
anyone? before it goes on ebay..
Old Dec 3, 2008 | 05:34 PM
michaelnyden's Avatar
do you still have this? I will offer $250 shipped.
tarun900
19
Dec 20, 2021 06:57 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
BobTX10
Oct 7, 2015 08:43 AM
