FS: VQ35 Swap Parts! 02 Maxima ECM, Immobilizer, Ignition w/ Key, eGas, & Cluster
Old Jul 8, 2009 | 12:08 PM
Aaron92SE's Avatar
NWP Engineering.com
Edit: SOLD!
I found these pieces at my local junk yard when I was doing my own VQ35DE engine swap. I have a 5.5g Cluster, ECU & NATS w/key & ignition, Steering Wheel, Steering Column, egas pedal assembly with APP Sensor $400 OBO.
Everything came from the SAME car! This is very tough to find. The Immobilizer, Ignition, Key, and ECM all match up perfectly. Came out of a 2002 Nissan Maxima Automatic with 96K miles
Please contact me with zip code for a shipping quote. I will be able to remove the ignition switch from the steering column so you can save on shipping. Most swaps I've seen don't need to change steering columns. The price is the same even if you do want the steering wheel and column.
Old Jul 17, 2009 | 10:43 AM
Aaron92SE's Avatar
NWP Engineering.com
If anybody is interested in purchasing a particular item, please note that there will be a delay in shipping.
All NWP Engineering products still ship within 1 business day. This shipping delay only pertains to the items in this thread since I will not have access to ship these items right away.
I apologize for the inconvenience. If you would like to purchase an item in this thread, please contact me. You will still be able to send payment and purchase an item, but your package will not ship until July 30th.
Old Jul 20, 2009 | 06:19 PM
KRRZ350's Avatar
Free bump for a great seller
Old Jul 28, 2009 | 07:32 PM
Blackwind's Avatar
will that steering column bolt right into a 4th gen?
Old Jul 29, 2009 | 08:15 AM
Aaron92SE's Avatar
NWP Engineering.com
I don't know about that one. But if you are doing a 3.5 engine swap into a 4th gen, then it will be much easier to keep your stock steering column and just use all the other parts I have for sale. You don't even have to use the ignition key, but you do need the NATS and key along with ECU.
Old Aug 10, 2009 | 08:48 AM
Aaron92SE's Avatar
NWP Engineering.com
Still for sale and ready to ship immediately!
Old Nov 25, 2009 | 09:28 AM
Aaron92SE's Avatar
NWP Engineering.com
Still for sale! Come on guys! I pulled all these parts from my local wrecker knowing someone on the org would need them for a Full ECU swap.
Old Jan 8, 2010 | 09:01 AM
Aaron92SE's Avatar
NWP Engineering.com
Bump!
Old Jan 11, 2010 | 02:10 PM
ajcool2's Avatar
I think everybody is scared of a little wiring lol.
Free BUMP
Old Jan 11, 2010 | 02:38 PM
Aaron92SE's Avatar
NWP Engineering.com
Free BUMP
Haha yeah. I think so. These parts can be a little tricky to find all from the same car too. That's why I pulled all these parts from my local salvage yard when I was already pulling my swap parts from another Maxima. I couldn't believe they had two 5.5 gens in near perfect condition!
Old Jan 13, 2010 | 07:08 AM
BenStoked's Avatar
Jesus was a Zombie.
If I could fab up a vq swap like you did, I would soooo buy this.
since I suck like that, free bump
Old Jun 1, 2010 | 06:48 PM
sergofast's Avatar
pm sent
Old Jun 1, 2010 | 06:55 PM
maxima 21's Avatar
I have the vq35 from an 06. Will these parts still work? my 4th gen is a 5speed. Is that going to be a problem? Also, Will i still need to do a cable driven tb if i do the ECU and all that?
Old Jun 2, 2010 | 08:04 AM
ajcool2's Avatar
Might want to read up a little more on the swap.
Old Jun 2, 2010 | 08:30 AM
Aaron92SE's Avatar
NWP Engineering.com
Originally Posted by sergofast
pm sent
Back at you.
If you are wanting to do a full ECU engine swap, then you will need all the parts I'm selling. Since it is an automatic ECU, the only two codes you will get are CAN line errors due to not having a TCM. But it will work just fine.
If you want to do a cable driven TB, you will need a different ECU. But going with the full ECU and all the wiring is the best type of swap. You will be able to take advantage of the CVVT. You can't do that if you want to use your 4th gen ECU and go cable driven.
Old Jun 2, 2010 | 08:47 AM
maxima 21's Avatar
My unlce is going to be helping me do the swap so im going to talk to him about this. Ill let you know here soon. I am interested though.
Old Jun 2, 2010 | 08:49 AM
Aaron92SE's Avatar
NWP Engineering.com
No problem.
Old Jun 7, 2010 | 10:18 AM
eng92's Avatar
Except for no cruise and a perma-CEL
Old Jun 7, 2010 | 10:35 AM
Aaron92SE's Avatar
NWP Engineering.com
Yes, the engine will run just fine though. That's what I was referring to. The CEL will come from the CAN line errors I mentioned due to not having a TCM.
Old Jun 7, 2010 | 10:48 AM
eng92's Avatar
Actually that is the way I have been running mine for the last two years. I miss the cruise though. I lost the #2 coil output from my 6MT ecu (measuring directly on the pin) about 2 years ago. An auto ecu was all that was available at the time locally.
I just got a spare 6MT ecu/key/NATS that I will have to throw in there one of these days.
Old Jun 7, 2010 | 10:57 AM
Aaron92SE's Avatar
NWP Engineering.com
So your ECU just quit on you or did you damage the actual pin on the ECU?
I am using a 6spd ECU right now and got my cruise working, which is nice. I am wanting to convert to a Z33 ECU in order to get the UpRev Osiris working for better tuning capabilities. The way I am thinking about doing it would eliminate cruise control and automatic cooling fan control. The fans will be easy to fix, but the cruise will probably be scrapped for life since I'm not willing to mess with the BCM from a Z or keep the 02 Maxima ECU and run it parallel to the Z ECU. I just want a simple Z ECU with Orisis.
Old Jun 7, 2010 | 11:14 AM
eng92's Avatar
No pin damage. It was internal to the ecu. I think it was related to the EMU problems I had. I had an EMU installed for a while and then one day I started frying my #2 coilpack (bulging out the side) I would get about 20 minutes of engine running time on a new coil before it would start misfiring. After the third coil went, I pulled the EMU and everything was good for several months. Then one day, no pulse signal for #2 at all. I threw an auto ecu in w/key & NATS and it has been good ever since (2 years now).
That sounds like an interesting project. I have not looked at a Z33 wiring diagram since I did my UTEC (a couple of years ago now) so I really do not have much insight into the cruise issue there.
Old Jun 7, 2010 | 11:24 AM
Aaron92SE's Avatar
NWP Engineering.com
Nice. Thanks.
Old Jun 11, 2010 | 10:25 AM
maxima 21's Avatar
I will probable be getting this here soon.... I just need to finalize a few things with what im doing. I have done quite a bit of research as far as the hybrid swap goes and non as for as the ECU swap goes. So now im attempting to find a write up for the full swap. If anyone has any direction for me I would greatly appreciate it.
Old Jun 11, 2010 | 10:29 AM
Aaron92SE's Avatar
NWP Engineering.com
Ok thanks. The closest thing you'll probably find to a full ECU write up is my swap thread. http://forums.maxima.org/all-motor/5...ss-thread.html
Also, search for threads started by eng92 and Jime. You'll find even more information. I also remember reading a good thread started by "made in china" I think that helped me with my swap.
Old Sep 6, 2010 | 09:43 PM
97flatblkMax's Avatar
Need Assistance with my 3.5 Swap
Whats up guys I have just gotten a 2005 3.5 motor with 55k miles on it with 5 speed auto would like to know what else would I need to get to drop it clean into my 1997 maxima
also I am in the nyc area i live in newark NJ do anyone know where I can get the 3.5 heads ported and polished would like your 2 cents on this Maxima family since my friends and I are going to be building a supercharger for it.
my friend has a 2002 3.5 clutch and im trying to do the 4th gen 3.5 auto
both supercharged.
Arron got any more parts for sale
Old Sep 7, 2010 | 09:22 AM
Aaron92SE's Avatar
NWP Engineering.com
both supercharged.
I don't have any other parts for sale that I can think of. Let me know if you are interested in the parts for sale in this thread. They are still available.
Old Dec 16, 2010 | 04:05 AM
240rr's Avatar
Do you still have these?
Old Dec 16, 2010 | 09:01 AM
Aaron92SE's Avatar
NWP Engineering.com
Yeap! Still available!
Old Feb 23, 2011 | 11:57 AM
Aaron92SE's Avatar
NWP Engineering.com
Bump
Old Feb 24, 2011 | 05:32 AM
93altima's Avatar
Turbo 4th Gen
how much for the ecu only
Old Feb 25, 2011 | 02:42 PM
Aaron92SE's Avatar
NWP Engineering.com
I'm sorry. I have to keep the ECU, NATS, and key together since they came out of the same car. They must match up or the car won't start without a NATS reprogram from the dealership.
Old Mar 3, 2011 | 10:35 PM
Blackwind's Avatar
ZIP 98208
Old Mar 7, 2011 | 08:51 AM
Aaron92SE's Avatar
NWP Engineering.com
ZIP 98208
I will give you free shipping to simplify matters. But, it will NOT include the steering wheel or column. But all the important components will be included such as the 5.5g Cluster, ECU & NATS w/key & ignition, and egas pedal assembly w/ APP Sensor.
If you want the steering wheel and column, it will be the same price, but shipping will be more expensive.
Let me know if you are interested. Thanks.
Old Mar 7, 2011 | 08:52 PM
Blackwind's Avatar
Ok,I'm still debating if I wanna go full swap or not, still reading up on it. Lots to learn.
Old Mar 8, 2011 | 07:19 AM
Aaron92SE's Avatar
NWP Engineering.com
Go full swap and take full advantage of the new engine!
Old Mar 8, 2011 | 08:46 PM
Blackwind's Avatar
now thats a sales pitch!!!
Old Mar 9, 2011 | 12:17 PM
Aaron92SE's Avatar
NWP Engineering.com
Sales pitch, ... truth. Same difference.
Old Mar 31, 2011 | 09:40 AM
Hey Arron did you come across any more parts I have 2005 motor and 5 speed auto trans you came across any parts that would help me complete the swap?
Old Mar 31, 2011 | 10:38 AM
Aaron92SE's Avatar
NWP Engineering.com
I don't have any other parts. What pieces do you need to complete your swap? Do you already have all the parts I have for sale?
