Are Polyurethane supension bushing that much better than the stock rubber ones?
Old Jul 10, 2002 | 05:30 PM
Blade_99SE's Avatar
Blade
Old Jul 10, 2002 | 05:58 PM
Nealoc187's Avatar
SLOW
I've had mine sitting in my garage for 2 months now. I should install those.
Having ridden in cars with PU bushings though, yes there I'd say there is a significant increase in suspension feel.
BTW does anyone know if there are DIFFERENT ES Bushing sets for control arms and sway bar endlinks? My set is for the control arms, but I think I've heard of people buying sway bar endlink sets.
Old Jul 10, 2002 | 08:16 PM
TurDz's Avatar
Neo,
Do you have those big ones, or the small ring type ones? I'm not sure, but I replaced every part that ES offered, and it made my ride very stiff and jagged without much increase in handling. I know now that you should replace only one of the kinds, and not all of them (like I did).
I'm thinking that you should replace the swaybar endlink bushings.
Old Jul 10, 2002 | 08:34 PM
breaux124's Avatar
From my understanding (and correct me if I'm wrong)
You can get Polyurethane parts for:
- The Control Arms
- The Front Sway Bar, main bushings (2 of them)
- Front Sway Bar End Link (4 of them)
You can get them through Courtesy Nissan, which also has additional discounts for Maxima.org members, just call and ask.
http://www.courtesyparts.com/energys...on/maxima.html
Old Jul 10, 2002 | 09:45 PM
TurDz's Avatar
Ok, I have a better feeling that you shouldn't get the control arm bushings. It won't do too much for handling, while the sway bar bushings will. I have both, and the ride is too stiff
Old Jul 10, 2002 | 10:14 PM
xHypex's Avatar
ES does offer the bushings for:
- The Control Arms (2)
- The Front Sway Bar, main bushings (2)
I have the endlink bushings on my car, and I hvae the FSB bushings sitting in my room. The control arm bushings are the hardest to get off, and sometimes have to be torched off from what I've heard. They are the ones that make the ride stiff as well.
-hype
Old Jul 10, 2002 | 11:32 PM
Nealoc187's Avatar
SLOW
When I purchased mine, I was under the impression that there was only one set of ES bushings available. Looks like I was wrong. I have the big control arm bushings. Looks like I purchased the wrong ones as far as handling is concerned. Dang.
Old Jul 11, 2002 | 01:12 AM
TurDz's Avatar
don't be disappointed. The only thing is, the endlinks are just a bit better and more effective. The ones you have might just make the ride stiffer.
Will you decide to install them? If you decide not to, you won't have to go through the hassle of torching those things off.
Old Jul 11, 2002 | 05:14 AM
BEJAY1's Avatar
Conecarver
Control arm bushings
I'm gonna revive this old thread bout the control arm poly bushings.
http://forums.maxima.org/showthread....0&pagenumber=2
3-4 people said it helped handling but nobody mentioned harshness or ride. Maybe they were all in new mod bliss at post time
Old Jul 11, 2002 | 06:34 AM
Lime's Avatar
on a slightly different point...what would SQUEAK over bumps in the rear? With all new OEM bushings.......just wanna get people's ideas on this one.
Poly parts will make your car noisy as hell, and stiff, but they last a long time, and they give more feel.
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
jaydot901
Sep 29, 2015 01:18 PM
