NEED HELP! leatherseats.com install....
Old Jul 16, 2002 | 06:33 AM
shaz's Avatar
Sorry for the double post but I really need help with this...
I started doing my install last night. Got the back seats done no problem, they look real nice. Started working on the front passenger seat. Got the bottom half (where your butt goes) all finished. I then started working on the upper half (where your back rests) and I got kind of stuck. I got the cover over the seat and sitting properly, but I cant figure out how the hell youre supposed to get the hog rings in (where the two-tone color is in the center of the seat). I tried to slide my arm up the front of the seat and put one in but its to tight. Am I doing something wrong? I cant see how you could do it any other way....you have to put the whole cover over the seat, so its unlike all the other hog ring areas where you have easy access. I thought the upper part of the front seat would be two pieces but its only one making the job almost impossible...Please be specific with any replies. Thanks
shaz
Old Jul 16, 2002 | 08:29 AM
redmaxpa007's Avatar
i SeE what you did therE
Re: NEED HELP! leatherseats.com install....
shaz
good question.. i will be runnning into this issue as well( as soon as they damn seats get here )
Old Jul 16, 2002 | 08:36 AM
shaz's Avatar
Re: Re: NEED HELP! leatherseats.com install....
you havent gotten your seats yet??? did they ship them to the wrong address or something?
shaz
Old Jul 16, 2002 | 08:59 AM
Re: Re: Re: NEED HELP! leatherseats.com install....
shaz
some how my oder was 2 seperate oders and both were waiting for the other to be finished(which both were finished) i called eric and say they would be sent out by friday.. so hopefully this friday... they will be here..
Old Jul 16, 2002 | 03:52 PM
95GoldMax's Avatar
Hey guys,
I installed my seats this weekend. it took a total of 10 hours with
my younger brother helping me. this includes the door panels too.
The only problems I had was using the hog rings. It took me an hour to put like 3 in place, and they
were loose. so I used WIRE TIES. 175 or so. They do the job just
as good.
I would say to use wire ties in the area of the front seat
where your back rests. its the only way to get them in there.
Old Jul 17, 2002 | 06:00 AM
shaz's Avatar
Originally posted by 95GoldMax
Hey guys,
as good.
wtf are wire tires? explain a little better...also, I noticed when I put my front passenger seat back together, there's like a 1 inch gap between the two pieces (right where the zipper is), is that normal? Or do I not have the seat on all the way, or did i make the bottom part to tight?
shaz
Old Jul 17, 2002 | 07:00 AM
LeftCoast's Avatar
shaz
I came across the same problem. To get around it, I placed the cover on and then "rolled" it up from the bottom until the lower portion position was above the headrest....like a sock. As I installed each ring, I rolled the cover down the seat. It worked pretty well for me. Let me know how it works out.
-Left
Old Jul 17, 2002 | 07:21 AM
shaz's Avatar
-Left
I did that, and i see how it works for the upper horizontal bar, but how can you roll it down further for the vertical bars?, they'll bend...
shaz
Old Jul 17, 2002 | 12:02 PM
2kSeattleMax's Avatar
Good instructions LeftCoast.
Place the top of the seat on, rolling the bottom of the seatcover inside out. Then, as your roll it back down, place the hogrings on the vertical pieces.
Roll up
Hogring on the way down.
roll a little more
hogring on the way down.
Its actually very easy once you figure it out.
Old Jul 17, 2002 | 12:16 PM
shaz's Avatar
Roll up
roll a little more
I understand what youre saying, but I still dont see how you slowly roll it down and ring the vertical pieces. wont they get bent?? as you roll it down the pieces will get bent and curve out...
This is starting to **** me off, if I could just finish this one part I could be done tonight thanks for all the advice though guys, I'm just not seeing it in my head properly i guess
shaz
maximaracer28
Apr 8, 2004 12:25 PM
csvencer
36
Dec 13, 2003 06:20 PM
Trunksu
Aug 11, 2003 11:54 AM
brodaiga
Jan 8, 2003 09:17 PM
