another gas related thread
Old Aug 1, 2002 | 07:47 PM
RKS's Avatar
RKS
I used supreme gas from Shell today and the 2K2 was knocking badly on heavy acceleration in 1st gear. Can the weather effect or cause the knocking since it was about 94 degrees today with about 50% humidity?
I also let a drop of gas fall on the rear quarter panel and I couldn't get off the mark it left even though I tried immediately after the spill, is this normal and how can it be removed?
Old Aug 1, 2002 | 08:30 PM
djPlayboy's Avatar
Re: another gas related thread
was the heck outa it, im not sure about the knocking though i live in louisiana the humidity here is proly twice that with the same 94deg temp.... i notice the knock also but only when i was using 20/50 weight oil that my stupid dealer**** was putting in when i switched to 5/30 syn valvoline knock disapeared.....
archie
Old Aug 2, 2002 | 12:37 AM
ivelweyz
All I know is that SHELL is probably the biggest piece of gasoline **** in the world, I'd take Amoco regular over Shell supreme...
Old Aug 2, 2002 | 08:08 AM
Str8ridin's Avatar
Re: Re: another gas related thread
Why? Do they use different refineries? Different beakdown processes?
Old Aug 2, 2002 | 08:54 AM
95maxrider's Avatar
Lightly modded
why? where are you getting this info from? any numbers to back it up? i use shell supreme, and i have had 0 problems relating to pinging, acceleration.....
seriously, if you know a website that did some test, i would love to see it. can we get some sort of gas analysis sticky too?
Old Aug 2, 2002 | 09:10 AM
Myrv's Avatar
Re: Re: Re: another gas related thread
Well, there's always this:
http://www.canoe.ca/CNEWSTopNews/shell2_may27-cp.html
The infamous bad fuel additive that Shell used which destroyed fuel systems. That's enough to stop me from using them.
Old Aug 3, 2002 | 01:09 AM
SunMax's Avatar
Re: Re: Re: Re: another gas related thread
Yup, I read it from the Vancouver Sun also.
Old Aug 5, 2002 | 09:15 AM
95maxrider's Avatar
Lightly modded
hmmm, interesting. but since i dont live in canada or use bronze gas, i think ill be fine. thanks for the article though.
Old Aug 5, 2002 | 09:27 AM
Jaws's Avatar
Ya, Shell really screwed up the bronze stuff, but Shell gas has much less sulpher than either Petro-Can or Esso gas. High sulpher levels are bad for your fuel and exhaust systems. Shell gas is consistantly is the 10 ppm range, the other 2 in the 250-300 ppm range. Current regs in this country (Canada) allow for 500 ppm, but in 2 years that drops to 30 ppm.
Old Aug 5, 2002 | 09:36 AM
H.N.I.C.95's Avatar
I saw on Dateline a few years back Some independent owners were adding water to their supply to lower prices.
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
