Would there be any gains from making the Y-pipe arms equal length?
Old Aug 4, 2002 | 01:51 PM
Anachronism's Avatar
It appears on the stock Maxima Ypipe that there was some effort to keep the branches equal length but it may be it was just necessary to shape it that way to accomadate the precats. The first generation stillen pipe used an equal length design, did that show any better gains than the current aftermarket y-pipes? Could en equal length pipe be made that would give better gains?
I was just reading an article on the new Ducati V twin motorcycle that uses a two into one exhaust design. It mentions that on the old bike the pipe off the rear cylinder was a big tangle to keep the lengths the same. But on the new bike the front pipe was a bigger diameter to 'balance it all out and make the same power as the old equal-length system'. Could we see any gains from a y-pipe designed this way?
It is the September issue of Motorcyclist BTW
Old Aug 4, 2002 | 02:10 PM
NightRider's Avatar
Actually, the first generation Stillen version was not a great design. Trying to run equal length pipes resulted in a slight kink in the system. The bends were too severe and caused the car to lose some of its "gained" power. I've noticed that on the Budget pipe, however, that they used a smaller pipe in the rear to even things out a bit. That's a good design.
Old Aug 4, 2002 | 02:19 PM
Vyrus's Avatar
You're on at a sane hour?! What's the deal? Anything new on the FLP intake? Would you all be able to make it anytime soon?
Anachromism as Nightrider said all of the gains you would recieve from equal length pipes would be negligable with all the bends needed for them.
-Cyrus
Old Aug 4, 2002 | 02:37 PM
-Cyrus
You beat me to it, my next question was if you could make an equal length Y-pipe without any kinks would it show any gains over the pipes available now? Could we expect any significant gains from this? Has anyone dynoed a budget Ypipe vs Cattman or warpspeed?
Old Aug 4, 2002 | 02:48 PM
Vyrus's Avatar
I don't think you could make an equal length pipe without many bends. It's just not possible unless you are willing to sacrafice a lot of ground clearance. I don't know much about the budget pipes, you should probably try searching.
-Cyrus
Old Aug 4, 2002 | 03:41 PM
xHypex's Avatar
I'm about to get a WSP after having a first gen Stillen pipe, so maybe I'll be able to tell the difference. The only problem is now I have a VI :P
-hype
Old Aug 4, 2002 | 06:28 PM
Dave B's Avatar
Not DAVEB the parts guy
I had the Stillen equal-length Y-pipe and now I've got a WSP non-mandrel Y-pipe. On the dyno, I gained more power at all rpms above 4000 plus the WSP is much quieter (thick gauge metal, lined flex). How's that?
Dave
Old Aug 5, 2002 | 02:19 AM
NightRider's Avatar
-Cyrus
Yeah, I wasn't too busy earlier. I've been really tied up because school is starting soon and I'm starting a new job. I'll be able to make that pipe for you. I can do $60 plus shipping. What color do you want?
Old Aug 5, 2002 | 05:44 AM
Dave
Yes but it was already stated that the first generation stillen pipe was a poor design, I think it was smaller than current aftermarket Ypipes also. If a equal length Y-pipe that was designed well and the same diameter as current y-pipes would we see any gains or possibly a smoother power curve?
Old Aug 5, 2002 | 09:44 AM
Vyrus's Avatar
Consider is done. Check your eMail. (If you didn't get anything for some reason eMail me at CMistry@Charter.net)
-Cyrus
Starrider
Dec 18, 2015 04:43 AM
Violator
Sep 9, 2015 10:14 AM
Adoubi21
Dyno Discussion and Slips
Sep 7, 2015 09:34 AM
