QUICK HELP PLEASE - STS install problem, my car is apart :(
Old Aug 7, 2002 | 11:56 AM
Anachronism's Avatar
STS install problem removing bolts
I am in the middle of my STS install and I am having a problem
http://vbxmaxima.8m.com/pics/shifter...rtassembly.jpg
I am truing to undo the nuts with the red arrows in the picture that will drop the whole shift assembly , but the bolt is turning too. They are very badly rusted. What should I do now?
Old Aug 7, 2002 | 01:14 PM
yourmove's Avatar
I had the same problem. You can get to the top side of bolt after removing shift boot. I believe (if I remember correctly), I used a center punch and knocked them out. The tops are pressed onto the threaded studs. Correct? It's not that big a deal. Once removed, replace with something other that the chincy OEM parts.
Old Aug 7, 2002 | 03:23 PM
Thanks, that is what I was thinking I was going to have to do. I got the shift assembly down by removing the other big bolt. Those bolts are still there and I cannot tighten or loosen them. I will have to go back and knock them out and replace them with regular bolts. The shifter feels a little loose because of these bolts now.
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
Finkle
Sep 27, 2015 09:53 PM
Samedi
Aug 12, 2015 01:54 AM
kirkhilles
Aug 8, 2015 10:53 AM
