no more cruise?
Old Aug 20, 2002 | 05:54 PM
maxichic's Avatar
no more cruise?
just when i think more tings can't go wrong... i hit the cruise control button n it's supposed to light up in green AND IT DDN'T! what the hell, cruise still works it's just that the option doesn't light up in green like it's supposed to, what did i do now?
Old Aug 20, 2002 | 06:04 PM
maximaracer28's Avatar
You can fix it by buying a new 2k2 edytka
Old Aug 20, 2002 | 06:19 PM
maxichic's Avatar
yes let me pull 30k out of my ***
Old Aug 20, 2002 | 06:20 PM
Ill buy it for you
Old Aug 20, 2002 | 06:21 PM
maxichic's Avatar
NOW CAN ANY1 HELP ME??????????? PLEASE
Old Aug 20, 2002 | 06:29 PM
costcowholesale's Avatar
check the fuse
Old Aug 20, 2002 | 06:57 PM
bert's Avatar
check the bulb
Old Aug 20, 2002 | 09:36 PM
maxichic's Avatar
now den and bert, where exactly is the fuse and bulb? how do i kno if they're burnt?
Old Aug 21, 2002 | 03:52 AM
JBWhitley's Avatar
The fuse is going to be in the little box under the stearing wheel behind the panel. Just remove the panel. I have a 2000 so I am not sure which fuse is for the Cruise. Just look on the inside of the panel and you will see a diagram. Find the Cruise and pull the fuse out. Look at it from the side when you get it out and you should see a metal peice going from side to side with a little curve in it. If the peice is broken, the fuse is blown and you need to replace it.
Old Aug 21, 2002 | 11:45 AM
chinaonnitrous1's Avatar
were you going over 90mph?.i know for me it dosent work at that speed
Old Aug 21, 2002 | 11:55 AM
maxichic's Avatar
no i was doin the speed limit (70)
Old Aug 21, 2002 | 01:01 PM
gepetto's Avatar
if you felt cruise engage, but the light didnt come on, then its the bulb
if neither happened, its most likely the fuse
did you make sure the little switch was pushed on? i know thats a pain sometimes. the only other thing i can think of is i know that the ECU has a vehicle speed sensor or somethin like but i dunno....im just guessin
Old Aug 21, 2002 | 05:34 PM
maxichic's Avatar
and where exactly is this bulb located/how do i get to it?
Old Aug 21, 2002 | 08:39 PM
DaddyMac's Avatar
open the hoos and look by the throttle body and follow the wire (there are 2). the one the goes through the firewall to gas pedal and the other should go to a box (that's the cruise). maybe it got knocked off.
something else to check
Old Aug 21, 2002 | 10:40 PM
Dave Holmes's Avatar
Re: no more cruise?
You could just leave it be and enjoy the fact that you don't have a green light on your dash to annoy you when cruise is on (especially at night). When you find out what it is, let me know so I can disable my light. Honestly though, if you want it to work, I'd check the bulb like someone else posted. Without taking mine apart, I'm not sure how to do that. I'll check on mine tomorrow if I can get around to it. Let us know if you figure it out before then.
Dave
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
schmellyfart
Sep 25, 2015 04:47 PM
jchronis2552
Sep 21, 2015 05:52 AM
Maximeltman
Aug 31, 2015 01:01 PM
