For those of you who go to the track
Old Aug 29, 2002 | 04:47 PM
TurDz's Avatar
How do you remove the white numbers that they write on your window before you drag or auto-x??
I can't seem to remove it with any kind of solution. thanks
Old Aug 29, 2002 | 04:48 PM
costcowholesale's Avatar
try goo gone?
Old Aug 29, 2002 | 04:50 PM
matt calder's Avatar
Re: For those of you who go to the track
razor blade
Old Aug 29, 2002 | 04:59 PM
TurDz's Avatar
Re: Re: For those of you who go to the track
Originally posted by matt calder
razor blade
I wouldn't really try that, I dunno, I would hate to scratch the windows.
I tried goo gone, didn't do ish.
thanks for your input though. Anyone else?
Old Aug 29, 2002 | 05:02 PM
MaximaZero's Avatar
Needs non-Maxima Friends
Re: Re: Re: For those of you who go to the track
steel wool? i think that's what they use to remove tint. dont quote me on that though!
Old Aug 29, 2002 | 05:06 PM
soundmike's Avatar
Very sound, Mike
Apply Rain-X before you go. Better have them have problems putting the number on than you taking it off
Old Aug 29, 2002 | 05:12 PM
mzmtg's Avatar
Minister of Silly Walks
Razor Blade...it wont scratch the glass...
Lime's Avatar
hehe you can't scratch the window with the razor blade. Apply the blade FLAT on the glass, and move it in a steady motion remaining at the same angle. To get stickers/shoe polish off glass, that's the best way. Applying Windex can assist as well.
Old Aug 29, 2002 | 05:15 PM
clee130's Avatar
My library card.
Old Aug 29, 2002 | 05:18 PM
Chebosto's Avatar
RIceD OuT moDErAtor
$20!
hahha .just kidding
if you spray Simple Green and let it soak a bit before srubbing it comes off. normally its just shoe polish.
Old Aug 29, 2002 | 05:19 PM
ericdwong's Avatar
steel wool
Old Aug 29, 2002 | 05:22 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
razor blade and windex is the best way, i do my car like that all the time and no scratches. i did about 10 maximas the night after maxus last year, i was the only one witha blade.
Old Aug 29, 2002 | 05:28 PM
TurDz's Avatar
I like the credit card idea. lol
Actually I'll try my Xacto blade. Thanks for all of the help.
Old Aug 29, 2002 | 05:45 PM
Shadow's Avatar
Be careful with an exacto blade, it's at an angle and if you scrape hard enough, you can scratch the glass. I know because I've done it before removing vinyl graphics with an exacto.
Why are the numbers so hard to get off? At the track I go to, water wipes off whatever they use to write the numbers. It rained after I went the last time and half the numbers washed off in just that.
Old Aug 29, 2002 | 07:00 PM
craaaazzy's Avatar
have the razor at a really deep angle, ie. pretty flat to the window like lime said. it'll only scratch if u have a point on it. make sure the razor is nice and clean and has a smooth edge.
Old Aug 30, 2002 | 04:34 AM
JAY25's Avatar
Originally posted by Chebosto
$20!
hahha .just kidding
as cheston posted it is only shoepolish it will come off with soap and water. It did when I washed my car two weekends ago.
Old Aug 30, 2002 | 05:15 AM
Virus's Avatar
Shaklee Basic H (www.shaklee.com) 1 qt=6900 bottles of windex and by changing the solution you can use it for just about anything. I put it on my hands full strength when working on the car. It acts like a glow so when you wash the oil and grime off, it just comes right off.
Old Aug 30, 2002 | 05:28 AM
nismo2020's Avatar
and 1
Old Aug 30, 2002 | 07:12 AM
max7's Avatar
Just use a razor blade! I always do and my windows are not scratched! Hoe did you do at the track?
Old Aug 30, 2002 | 08:05 AM
blizz20oma's Avatar
I'm so hood
I've only had to deal w/it once, and just went up to the car wash I used to work at & used the solvent there. Came off instantly with a wipe or two. Same solvent they had us use for tar on rocker panels and anything real sticky on windows (if I see anyone make the obvious comment here, they're getting a )
I'm not sure of the brand name product but similar in function to some products mentioned earlier in the thread. No scratchage needed.
soap/water/hard scrubbing didn't do nothin for what they put on my windshield.
Old Aug 30, 2002 | 07:56 PM
92vemaxse's Avatar
Rubbing alcohol and a credit card, never fails me!
Old Aug 30, 2002 | 11:00 PM
2K1HoMax
razor blade
ditto, i made the mistake of windex be4 and all it did was smear the stuff all over the place. it dried the next day i was at it with a razor blade for like an hr tryin to get all the small pieces off the car and the rubber **** around the windows. really anoying.
Old Aug 31, 2002 | 02:38 PM
TurDz's Avatar
I didn't do as well as I expected, not even close. I'm going to try to use m 15'' blades the next time I go. I know I'll do better becuase i have a feeling my potenza re730s + 17'' wheels weigh a TON.
btw, the stuff they used to write my numbers on my car could not be removed with any cleaning solution I had. Dishwashing soap, Simple Green, Goo Gone, Windex all couldn't take it out. Heck, even my Eimann Fabrik undiluted didnt' even do the trick.
The razor blade method worked fine.
mkaresh
Mar 12, 2018 06:48 PM
jonreidhead
Jan 6, 2016 09:38 AM
