Help...what would cause steering "groans"...
About a month ago, I started hearing a hollow "Groan" (NOT a belt slipping "screech") whenever I turned into parking spots at slow speeds. Not it's doing it at higher speeds like turning corners and an occasional tight on-ramp. It almost always does it on a right turn, and maybe 80% on a left turn. I tried draining the steering fluid and replacing w/ synthetic, and at the same time flushed the coolant system, and the noise went away for about a week, but now it's back. Any ideas as to what might be causing it and how to remedy??? I'm getting worried that my mileage is taking a toll on the poor car.
You turning full deflection?
No idea if this will help, but my old Celica will groan when I turn full deflection (against the stops). There's supposed to be a plastic bushing on the end of the steering stop (a bolt basically) and with that worn away, it's metal contacting metal. But then my Celica is 17 years old and has almost 150,000 chassis miles
Re: You turning full deflection?
i hate not having power steering
that **** sucks. if i slow down to turn a corner the steering wheel get stiff. i have to fight with it to parrellel park. when i leave my drive way the whole town knows. it just makes this annoying sqeeking noise. i have to turn the wheel all the way in both directions to get rid of the noise.
Just a suggestion... I could be wrong... but if you got new tires it could be that too...
Do you notice it only when the car is cold or even when its warmed up?
I had a '69 mustang when I was in HS and I remember not having power steering on that puppy, parallel parking was b*tch.
worldwiderecognized
Sep 30, 2015 01:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
