Boosty Quest: to Be or Not 2.87...
Old Sep 10, 2002 | 09:29 AM
Chebosto's Avatar
RIceD OuT moDErAtor
the blower is off in wunderland to Vortech...
so now. what to do.
2.87 and get 13 pounds?
or keep my "stock" pulley.. wink wink.
if you may recall..
3.60 The Norm
3.48 The Elf
3.33 The Fairy
3.25 The Dwarf
3.125 The Midget
3.0 The Pixy
2.87 The Urchin
Itchin' for Urchin..
--ches.
Old Sep 10, 2002 | 09:39 AM
Sprint's Avatar
Old Sep 10, 2002 | 09:46 AM
DTR Maxima's Avatar
Urchin= one happy and largly boosted Cheston
Old Sep 10, 2002 | 09:52 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
You need to catch up.
Old Sep 10, 2002 | 09:55 AM
Maximamike's Avatar
You wouldn't do it..
Old Sep 10, 2002 | 10:38 AM
matt calder's Avatar
2.0 Chiggers
You are itching for the chiggers
you can doit
Old Sep 10, 2002 | 12:38 PM
MardiGrasMax's Avatar
IHMO to go smaller than a 3.0 you should consider larger injectors. You can run the fuel pressure up really high and make it work but you stand the chance of injector lock up. Go for the 2.6
Old Sep 10, 2002 | 01:09 PM
Chebosto's Avatar
RIceD OuT moDErAtor
perhaps the 3.0..
Old Sep 10, 2002 | 01:14 PM
JAY25's Avatar
Like he said above just make sure you upgrade your injectors!!
10PSI is not nuff for you my friend?? then knock yourself out and welcome the urchin!!! , besides kev said you need to catch up!!
Old Sep 10, 2002 | 01:42 PM
Y2KevSE's Avatar
Originally posted by Chebosto
perhaps the 3.0..
Buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck buck
Old Sep 10, 2002 | 01:44 PM
dashingMax's Avatar
Dont do it
You have a nice car & lets keep it that way. Do you really drag race...professionally?
On the street, do you seriously need 13 psi boost.?!?!
3 things even after you upgrade the fuel injectors
(1) You are running that "rebuilt" blower faster than the recommended impeller speed.
(2) On stock 10:1 compression, 13 psi seems too high and that excessive stress can cause internal engine damage.
(3) You will definitely need air-to-water intercooler & maybe water-methanol injection to keep things cool under the hood.
Since you're getting the new 350Z, why bother risking blowing your engine? Just stay put & save the money for the 350Z mods.
Bobby
Old Sep 10, 2002 | 02:04 PM
gtr_rider's Avatar
192.168.1.1
max7's Avatar
Just wait and upgrade the Z. On the other hand if you want that thing to be really fast than go for it. Just make sure you get bigger injectors.
Old Sep 10, 2002 | 02:08 PM
dashingMax's Avatar
Originally posted by gtr_rider
He is trying to mimick the sounds of a chicken.
I'd say, be a chicken with 300+ horses rather than
a lion with a blown engine.
Old Sep 10, 2002 | 03:56 PM
max'n out's Avatar
U upgrading the blower or just getting some service? If you are upgrading man just call it a day and get teh 2.62.
Old Sep 10, 2002 | 04:20 PM
Cumalot's Avatar
To be honest, I don't know why you even want to continue to mod the Max. With a 350Z on the way, why bother? If it was me, I probably would sell the Max. You know when you get the 350Z, sooner or later, you will mod that car too whenever parts come out for it.
Old Sep 10, 2002 | 04:24 PM
Ramius83
Well, its not like it will cost you much to upgrade to a smaller pulley. But possibly, with this upgrade, many things down the line will/might be needed to keep your car tuned properly, ie. intercooler, H20 injection, larger injectors, etc. But of course, when you get your 350Z, it won't really matter lololol.
aackshun
Feb 6, 2021 05:37 PM
MaxLoverAz
31
Jun 19, 2010 10:48 AM
