any1 w/97-99 & RT cat have MIL prob?
Old Sep 7, 2000 | 07:35 AM
JeffO
Old Sep 7, 2000 | 08:16 AM
Vic's Avatar
Vic
Had it for awhile..and not a problem...
Vic
Originally posted by JeffO
Old Sep 7, 2000 | 10:06 AM
pretty common....
you mean the rt cat...do you have a y pipe?? the mil code is typically 702 which indicates a problem w/ the o2 sensor in the cat....something about the cat moves the 02 sensor closer than the stock cat to exhaust gasses are hotter, etc....it's no biggie, just a pita, reset it....shingles has it also, a few others here...
nuthin to worry about
Robert
Old Sep 7, 2000 | 10:26 AM
GregP's Avatar
I have a 99 CA-spec Maxima with Y-Pipe, RT cat and Courtesy B-Pipe. I have no problems with the MIL light, but then again if I understand the reports here right - I wouldn't be affected since my 99 does not have any O2 sensors after the cat.
Old Sep 7, 2000 | 10:37 AM
Shingles's Avatar
The missing moderator
Yup code is abour rear O2...
The thing is, it only seems to happen for me when it's hot.
Old Sep 7, 2000 | 10:39 AM
JeffO
if i add b-pipe/muffler then would it be
ok? this would cool the O2 then.
Old Sep 7, 2000 | 11:34 AM
the only way i've noticed to stop the mil
light from coming on is to put in the 95 jwt ecu.
it doesn't recognize that 02 sensor there and thus doesn't see the problem
Robert
Old Sep 7, 2000 | 12:56 PM
98MAX's Avatar
But is the RT cat realy worth getting?? nm.
nm
Old Sep 7, 2000 | 06:48 PM
ronskal
I didn't notice any difference with the RT cat. Your Max may benefit cause it's a heavy breather with Nitrous and all.
maxinout93
Oct 31, 2015 02:04 AM
lrb6805
Sep 18, 2015 07:07 PM
Justin Kroll
Sep 2, 2015 11:06 AM
