Need help on wheel and spacers!!
My friend just order a set of new rims and tires:
235x45: 17x8 : offset is 45 and his driving a 96 maxima.
will this fit fine on his car or do he need a spacer (rear and front)??
If he does which brand do you recommand.
Originally posted by Nightkidz
His worry about the wheel being too wide and the offset. Should he return the rims and exchange the a different one that will fit better.
Can you suggest the best combo.
Your setup should work just fine. I am not so sure about 45mm offset, especially, the 8" wheel width. If you had 7" wide rims, they should fit A-okay.
Like voltman suggested, try 'em on & if they rub, you WILL need some spacers, atleast 5mm.
Andy29
Sep 29, 2015 05:32 AM
