People with Drag Slick knowledge: What PSI should I use at first?
Old Sep 12, 2002 | 07:06 PM
Nealoc187's Avatar
SLOW
I was thinking of starting out at 14psi and working my way down from there.
Has anyone ever used dishwashing liquid to coat the inside of the tire and seal the bead? Has anyone gone without it? This was suggested to me by the man I spoke to at M&H.
Also, is there anything I need to do to prep the slicks for their first run besides a nice burnout to heat em up and clean em off?
Old Sep 12, 2002 | 08:04 PM
SR20DEN's Avatar
VQ Wizard
Re: People with Drag Slick knowledge: What PSI should I use at first?
I used dishwashing liquid to do that. I put the slicks on the tires by hand, the liquid was mainly for lubrication.
im still not sure what the optimum pressure is though. I'll probably know by Sunday.
Old Sep 13, 2002 | 03:49 AM
Blu's Avatar
Blu
the tits
Please spare the trouble and get them mounted. Mounting them by hand was the biggest pain in the ***. Just sharing my experience SR almost broke his arm when he was mounting one his arm got stuck between the wheel and the tire when it popped on. He was a gimp for the rest of the day
Old Sep 13, 2002 | 05:35 AM
SR20DEN's Avatar
VQ Wizard
Yeah I was looking at my hurting wrist like .
Old Sep 13, 2002 | 05:39 AM
Blu's Avatar
Blu
the tits
sealing the bead was a PIA also
Old Sep 13, 2002 | 06:12 AM
MardiGrasMax's Avatar
13 was good for me, I started at 16 and worked my way down. You will feel it as they get better. Mine felt like they were still spinning a bit but my 60's were 1.9's so I wasent worried. I was launching at 5k with just boost. So launch it hard and dont worry!
Got AAA?
Old Sep 13, 2002 | 06:15 AM
Blu's Avatar
Blu
the tits
so whens your 12 sec pass gonna be. 12.5 should be no problem with slicks for all that power
Got AAA?
Old Sep 13, 2002 | 12:10 PM
Larry's Avatar
Get some AmerSeal tire sealant (or equivalent) from Wal-mart to lub and seal the tire to rim. No tube is needed for slicks with tire sealant and it also helps keep the tire from turning on the rim. I have ran as low as 10 psi on a 1.36 60' and no problem without rim screws. With my Mustang that is!
If you have your tires installed at Discount then have them put the sealer on. They carry a good sealer that works great too.
With the tire manufactures recommended width rim for your size slick, you will be able to run more pressure and hold traction. The tire will not crown and will leave a wider foot print with the correct width rim. The more pressure you have the less drag on the top end as long as you stick when launching.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
REDinLV
Sep 28, 2015 12:31 AM
