Why do nissans have the Mass Air flow?
It rugulates air or something right?Why dont hondas have this?
It seems like it would srestrict alot of air going in the intake mani.
Just curious.
Anyone ever drive without one?Or try and trick the ECU?Damange?
Just curious.
Re: Why do nissans have the Mass Air flow?
Just curious.
Just curious.
Hondas I believe may have also gone the way of MBenz in using SOHC not DOHC nowadays.
Originally posted by voltman
I've heard that you get more power from your intake if you remove the filter.
Just curious.
Just curious.
Honda - Manifold Absolute Pressure Sensor
Both serve more or less the same function.
This is why when you boost some Honda's you need a check valve to prevent it from sensing boost which will set off a CEL. A MAFS should just register more flow.
BTW, it measure's airflow so it know's how much fuel the engine needs (and some other stuff). It doesn't restrict airflow.
MaximaDrvr
08-19-2015 08:20 PM
Team STILLEN
08-10-2015 04:29 PM
kirkhilles
08-08-2015 10:53 AM
