Maxima Trouble
Old Sep 16, 2002 | 06:23 PM
DaveGrun's Avatar
Maxima Trouble
Here's the story. For longer than i can remember, my 96 auto se has absolutely horrible low end power. Today, i thought it might be the throttle cable. So, i tightned it up a little and took a drive. The idle was normal and the pedal felt much stiffer but still had crap low end. So i decided to check the ecu, since the CEL wasnt on, just to make sure. Turns out it was giving me 0304. So i just figured i needed a new knock sensor. By the way, i have been getting horrible gas mileage too. However, about an hour ago, 5 hours after i tightned the cabe, i took a drive in my car. It was idiling at about 500 and less rpms, and shaking like crazy. I dont think it is related to the cable tightening. Also, this morning before my idle got messed up, i took out the air filter with the engine on, to wipe it off to see if that had any effect. I think i have a more complicated problem now than just a bad knock sensor. Thanks.
Old Sep 16, 2002 | 06:40 PM
UMD_MaxSE's Avatar
Got Bent?
a bad knock sensor will cause you to have power loss since it will be retarding engine timing unecessariy. This will cause you to get bad gas mileage also. I would replace that first.... also try cleaning the throttle body if it is dirty...
Old Sep 16, 2002 | 06:50 PM
Mishmosh's Avatar
Re: Maxima Trouble
Definitely get a new KS.
The shaking may be due to an intake leak... Did you adjust any vacuum lines to the intake or did you just play with the air filter?
Slamrod
Apr 10, 2016 05:24 PM
Goffery2uned
Aug 21, 2015 09:50 PM
laparka66
Aug 6, 2015 09:36 AM
