Okay CF hood is on...
Old Oct 1, 2002 | 01:30 PM
James12345's Avatar
First of all the quality/finish is superb. Got a nice little metal plaque thingy on the underside that says Fiber Images and some number (serial number?).
It's also got Fiber Images in the top of the hood in the middle right down in the front of the windshield kinda.
Only problem is the fit. It lines up perfect and everything, only the latch wont let it come down flush in the front.
There's about an inch in between the hood and the grille/lights, and in return some space in between the hood and the fenders (vertically).
Is there anyway to get the latch to catch lower down? That's the only hold up here. If I can make it latch about an inch lower then I'm good to go.
I'm almost tempted to just cut off that latch (the U-shaped metal thing) on the underside of the hood. Then the hood will be able to sit flush and use just the hood pins to keep it down.
Thoughts?
Old Oct 1, 2002 | 01:36 PM
1MAX2NV's Avatar
You can adjust the latch some. By loosen the bolts and moving the whole assmbly down a bit.
Old Oct 1, 2002 | 02:10 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
if not bust out the dremel
Old Oct 1, 2002 | 02:12 PM
thebigsadler's Avatar
this is what you do:
take the latch off the car, and drill out the holes a couple of sizes bigger..
then take the latch and latch it to the hood itself (may need a friend to help you push it onto the hood)..
then pull the hood down to where you want it to sit and bolt whatever bolts you can up, i have 2 holding my latch in place, but my hood fits near perfect, and i mean DAMN near perfect!!
hope that helps.
Old Oct 1, 2002 | 03:10 PM
James12345's Avatar
I had to mess with the latch behind the grille. It's held in by 3 screws making a V shape. I figured out that they are adjustable, but by maybe 1/4" at most which isnt enough.
So what I did was cut out the top portion on the two upper bolts. Not just widening the hole but totally cutting out the top part of the metal making it a U-shaped cut-out. The bottom hole didnt allow for this so I just discarded it.
Now that I had the U-shaped cut out, I pushed down the latch as far as it would go (it stops on a support bracket and cant physically go down anymore). Then I used larger diameter washers instead of the stock ones to hold in the latch now that they're u-shaped to get as much metal on metal as I could.
Now it's flawless except one side (passenger) kinda rides up a bit in the front. The hood pins will take care of that.
The sides could go down a little bit more flush with the fenders, but I'm not complaining. It's not bad at all and definitely good compared to some of the other hoods I've seen.
I dont know if I can get pics for you guys tonight. I'm in a mad rush to cram for a huge Gov't test that I have to go take in under an hour. Shoulda gone over the material earlier. Argh. lol
They'll definitely be up tomorrow. And BTW, this is on my 5spd, not the blue one in the sig.
Old Oct 2, 2002 | 01:53 AM
EZEMaxima's Avatar
Try twisting down the two black rubber stop on each corner located on your radiator support to lower the sides of your hood.
Old Oct 2, 2002 | 05:46 AM
redmaxpa007's Avatar
i SeE what you did therE
nice.. good job.. that is basically what everyone has to do to get the hoods to sit properly.
Old Oct 2, 2002 | 05:48 AM
Sprint's Avatar
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
