Off subject "any software guru's"
Any one really good with software. My PC will not launch Internet explorer. It will only come up to a lanc white page with nothing on it. Internet connection is working because can get on instant messenger. Tried reseting IE but no luck. Any help would be apreciated. Thanks
CTRL-ALT-DEL see if the Task of IEXPLORE.exe is running.. if it is.. you might want to shut it down.. try again.. if it still doesn't work.. go upgrade it..
http://www.microsoft.com/downloads/r...=top&ordinal=4
oh IBTL
oh IBTL
oh IBTL
oh IBTL
Tried to upgrade but wouldn't connect to download site. Really wierd though everything will connect but IE and weatherbug. Also this just started lastnight was on web surfing and went to open a page and just white screen wouldn't load or anything. Thanks for the help
here is the setup file http://64.252.156.63/ie/
you can't get the setup file? or the setup file won't connect to microsoft?
Nope will not connect to website or anywebsite I downloaded from my laptop and onto a floppy the setup file put in my PC and ran ask me if I wasnted to install and the would go no father.
the only other option i could give you is involved with editing the registry.. and i don't feel comfortable tellign someone to do that
maybe you should get like an Internet Service Provider CD that has IE on it.. or use another browser for now..
Try clearing your cache/cookies
go to tools>>internet options>>settings>>view files>>
Then on the memu bar go to>>edit>>select all>> then press your delete key.
If this works, then you might want to try increasing the size of the temporary files folder.
I thought IBTL meant In Between The Lines........lol.
Gotta be the wierdest thing I have ever seen all I did was turn the PC off for about 45mins and hen I powered back up works fine not sure what the prob was. Kinda crazy if you ask me but anyway it is working. Did tried to reboot twice befor so I don't know?
Originally posted by ILoveMyMax
FORMAT FORMAT!
FORMAT FORMAT!
hey mr. bonestock.. have you thought about upgrading the OS service pack? win2k is up to 3 now
Can you Ping?
Can you PING the site Sprint gave you?
If you don't know how:
Click "Start" -> "Run"
Type CMD
When you get the DOS window type "PING 64.252.156.63"
See if you get 4 "Reply to ....." messages.
If you don't, it's not your browser but your connection.
If you do get the messages, then your browser is definitely the culprit. You can do a search at http://msdn.microsoft.com to try and pinpoint your issue as well. Make sure you know your browser version (Click Help -> About Internet Explorer).
Good Luck.
Shaydz
Type CMD
Good Luck.
Shaydz
never have to format.. you can always reload the operating system over a new one and it will not affect your programs but may also help fix problems..
I have XP installing SP1 on it now so hopefully the problem doesn't reacurr. Thanks for all the help
check what Shaydz suggested.. but you said you had a connection.. so i guess other applications work too
Re: Off subject "any software guru's"
Go get mozilla (mozilla.org) and save yourself a world of pain.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
coasterswim
Sep 1, 2015 05:27 PM
IceY2K1
Feb 13, 2001 06:51 PM
TommyBoiSxty9
Oct 1, 2000 05:03 PM
