Fuel Filter = bad performance??
Old Oct 4, 2002 | 10:25 PM
ny96max's Avatar
Can a fuel filter with close to 60k on it make my motor perform badly?? rough idle, hesitation off the line, etc...
thanks,
Anthony
Old Oct 4, 2002 | 10:30 PM
Sprint's Avatar
yes.. its kinda like a dirty air filter.. just like clean air and low amounts of air would be getting to the engine.. same thing applies to the fuel filter.. it also lowers gas mileage..
when i changed my FF the car had better gas mileage and pulled harder
Old Oct 4, 2002 | 10:32 PM
Kashoggio's Avatar
cahnge your fuel filter every 30 k
Old Oct 4, 2002 | 10:43 PM
ny96max's Avatar
looks like ill be changing mine next week and cleaning my K&N too.
thanks Sprinty
Ant
Old Oct 4, 2002 | 10:55 PM
Sprint's Avatar
Fuel Filter
http://vbxmaxima.8m.com/fuelfilter.html
K&N Cleaning
http://64.252.156.63/tails/nissan_ma...n_recharge.htm
just in case someone uses the search feature later and comes across this thread
Old Oct 4, 2002 | 11:08 PM
Confused's Avatar
Permanent Maxima.org Resident
Re: Fuel Filter = bad performance??
you still haven't changed it??
thanks,
Anthony
Old Oct 5, 2002 | 03:28 AM
Dasyce's Avatar
Just a question, doesn't changing your fuel filter give you worse fuel mileage. Since you are installing a new filter that allows gas to flow to the engine more freely then a older more clogged up one.
Old Oct 5, 2002 | 05:47 AM
redmaxpa007's Avatar
i SeE what you did therE
well since you filter was clean to start with... no
Old Oct 5, 2002 | 05:49 AM
gepetto's Avatar
just because you can get more of something, doesnt mean you'll be using more. once you have a clean filter, it makes it easier to bring fuel in. therefore, a cycle that, with a dirty filter required 2X amount of fuel, with the new filter may only require X amount.
Old Oct 5, 2002 | 05:41 PM
Shannon and Ian's Avatar
Check your throttle body. I bet it is dirty too. When I looked at my wifes Maxima I was disgusted. I cleaned it out with a rag and a toothbrush and the low idle problem went away. It also shifted harder than a motha!
Old Oct 5, 2002 | 06:07 PM
NoMoreAlty's Avatar
ff
what brand is everyone using. i know fram oil filters suck but fram is the only FF i can find for my max in miami
Old Oct 5, 2002 | 06:12 PM
Re: ff
nissan brand
Old Oct 5, 2002 | 06:25 PM
BBaker025's Avatar
Im having Nissan put a 300ZX OEM filter in, its bigger than the maximas. I broke 2 spark plugs in the engine, so this is a good time for me to change it while its at the dealer. 77k miles and I think I still have the origional.
Old Oct 6, 2002 | 03:16 PM
ny96max's Avatar
just changed mine out like 2min ago. The car idles alot smother and accelertaes a lil quicker at WOT.
thanks for the info boys!
Ant
Old Oct 6, 2002 | 05:19 PM
Sprint's Avatar
told you
Old Oct 6, 2002 | 05:46 PM
Frank Fontaine's Avatar
Be honest now, are you a senior exec at K&N?
They claim the filter works better as it gets dirty. Fantastic, genious marketing! I fell for it and bought the filter and cleaning kit! Wouldn't want to hurt my engine by putting in a clean genuine Nissan filter now, would i?
Old Oct 6, 2002 | 06:00 PM
ny96max's Avatar
Originally posted by SprintMax
told you
i never doubted you
Ant
Old Oct 6, 2002 | 06:14 PM
Vyrus's Avatar
Are there any advantages to putting the 300ZX filter in? Is there any extra steps I have to do to put one of these in? Is it worth it over the stock one?
Thanks,
-Cyrus
Old Oct 6, 2002 | 07:05 PM
Sprint's Avatar
last twice as long..
but being that you memorized the 4th Gen FAQ like i did.. you should already know this
nope
Thanks,
-Cyrus
Only if you don't want to change the FF as often.. its kinda like copper plugs theory
Old Oct 6, 2002 | 07:07 PM
Vyrus's Avatar
nope
Good stuff... thanks Sprint. I'll go read those FAQs now.
-Cyrus
Old Oct 6, 2002 | 07:17 PM
ny96max's Avatar
im probably gonna start doin my FF every 15-20k just cause its so easy to change
Ant
Old Oct 7, 2002 | 12:59 PM
chinaonnitrous1's Avatar
hmmmm i "searched for a good fuel filter thread" i guess at 25k on my 2k2..its just about time..=)
Old Oct 7, 2002 | 01:30 PM
Mizeree_X's Avatar
Getting back to his roots
They claims that it filters better, not more. As the dirt accumulates on the filter, it makes the mean pore size drop, so smaller dirt particles are more likely to be stopped by the filter. However, the pressure drop across the filter rises, as the mean free path for air increases because the apparent filter width increases.
In summary: more dirt = better filtering, lowered performance.
Old Oct 7, 2002 | 01:32 PM
i guess there isnt a fuel filter onna 2k2..hahaha
Old Oct 7, 2002 | 02:02 PM
Mizeree_X's Avatar
I assumed he was talking about a K&N air filter, not a fuel filter.
Old Oct 7, 2002 | 02:29 PM
Where the reasoning doesn't make sense is more dirt = closer to being clogged, how is it better filtering? A clean element would have to allow dirt to pass through if more dirt is preferable to less. Lowered performance, it's true but why turn to the aftermarket to achieve that? Just hang around your local Nissan garage before their trash gets hauled away and get some dirty air filters.
Old Oct 7, 2002 | 04:55 PM
oopz..well this thread was originally for fuel filters..but whatever...i dont have one anyway...nor a K&N
The Wizard
24
Oct 1, 2015 08:47 PM
aminus21
Sep 12, 2015 04:53 PM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
