Some people think Ingen cai draws cold air:
Old Oct 17, 2002 | 11:59 AM
ArcticMax's Avatar
from some of the posts I've seen, people think that Ingen will suck in cold air because the filter is sitting behind the radiator.
Someone said that when the radiator fan starts spinning it will have the same effect as a PR Cai because the fan is drawing in air from the outside
Do you all have any idea how hot it is behind the raidator?
ESPECIALLY when the fan is blowing?
The air from the fan is the air that passed through the HEAT EXCHANGER!!
Open the hood up and stick your hand in behind the radiator WHEN the fan is blowing.. See hot the air is
Old Oct 17, 2002 | 12:00 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
plus isn't the inlet is situated very close to the "hot" tranny
Old Oct 17, 2002 | 12:02 PM
T-bone's Avatar
Re: Some people think Ingen cai draws cold air:
like I've said before, someone needs to stick a thermometer at close to the air entering the TB as possible. Then we'll have data.
Old Oct 17, 2002 | 12:14 PM
ny96max's Avatar
Injen = all looks and minimal gains
PR CAI = better looking, IMHO, and operates much cooler
Ant
Old Oct 17, 2002 | 12:27 PM
DA-MAX's Avatar
one advantage of Injen is no cutting though...thats good for guys who don't plan on keeping their car forever!
Ant
Old Oct 17, 2002 | 12:29 PM
redmaxpa007's Avatar
i SeE what you did therE
Ant
aaa
NO..
Old Oct 17, 2002 | 12:34 PM
Blu's Avatar
Blu
the tits
people who have the injen think its better. people who have PR think its better. people who have frankencar thinks its better.
Old Oct 17, 2002 | 12:36 PM
Jon91SE's Avatar
Pusssseeeehhhh
Only PR will suck in air from outside the engine bay...
Old Oct 17, 2002 | 12:51 PM
maximadave's Avatar
detailerdaveb@gmail.com
not true
try again
Old Oct 17, 2002 | 12:52 PM
thank you..
Old Oct 17, 2002 | 12:55 PM
SR20DEN's Avatar
VQ Wizard
They all suck.
Old Oct 17, 2002 | 12:59 PM
Sprint's Avatar
Injen is not a true Cold Air Intake..
Old Oct 17, 2002 | 01:02 PM
Kojiro_FtT's Avatar
Your stock airbox is the best CAI you will find. Notice is sucks air in from the grill but above the radiator? These engineers aren't idiots.
SR20DEN's Avatar
VQ Wizard
And when it's not cold outside none of them are.
Old Oct 17, 2002 | 01:05 PM
Sprint's Avatar
judging from the fact the black plastic from spare tire well is gone.. your theory is wrong
Old Oct 17, 2002 | 01:06 PM
Jon91SE's Avatar
Pusssseeeehhhh
Yea but it can be 90 degrees outside and a true CAI will still be sucking in cooler air then an engine bay...
Old Oct 17, 2002 | 01:07 PM
SR20DEN's Avatar
VQ Wizard
Is 90º air classified as COLD air?
umm no....
Old Oct 17, 2002 | 01:10 PM
Jon91SE's Avatar
Pusssseeeehhhh
umm no....
Well your right there, so we will call it a "cooler" air intake then
Old Oct 17, 2002 | 01:11 PM
Blu's Avatar
Blu
the tits
umm no....
SR20DEN's Avatar
VQ Wizard
Old Oct 17, 2002 | 01:30 PM
DA-MAX's Avatar
and people using the intake setup from a '95 Eclipse will think theres is better as well!
Old Oct 17, 2002 | 01:39 PM
Blu's Avatar
Blu
the tits
Old Oct 17, 2002 | 01:44 PM
deezo's Avatar
My thoughts exactly.
Old Oct 17, 2002 | 01:45 PM
BlackMax2k1's Avatar
At least spell it right dude.
Old Oct 17, 2002 | 02:08 PM
JAIMECBR900's Avatar
It's also the most restrictive. You can get a bucket full of cold air, but if you run it thru the stock air box, you'll only get out a cup full. Nissan engineers were not the first to think about getting air from a cooler source, racers were. They may not be idiots, just bad copycats.
Old Oct 17, 2002 | 09:36 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Re: Re: Some people think Ingen cai draws cold air:
No need for a thermometer, since any OBD-II scan tool measures and records your intake air temperature(IAT) sensor readings.
I don't think taking a measurement as close as possible to the TB really matters.
Old Oct 17, 2002 | 10:10 PM
iregula's Avatar
yeh dont u think the people who built our cars know about this stuff? in my opinion, the stock air box works very well. my sisters 92 max has a lot more jump down in lower end. i think those filter intakes add a little imaginary hp if u ask me.
Old Oct 17, 2002 | 10:22 PM
Newman's Avatar
they know about it but that doesnt mean they are going to use their knowledge. car companies go for the quiter route with a little less HP than to go the noisier route with a little more HP because most people dont want a loud car.
check out a dyno. it will show you for sure how much "imaginary" hp you are gaining.
Old Oct 17, 2002 | 11:07 PM
02MaximizedVQ's Avatar
Injen
Anyone who has installed an Injen on their 2k2 knows that there is no question there is power gain from 4000 rpm up. And the air filter actually sits below the radiator. Not directly in the path of the air. Airflow through the VQ engine bay is very good. AFter getting home from work the other night when it was 47 degrees, my Injen pipe was cool to the touch and so was the intake manifold. Plus if you wrap your intake with header wrap or other insulator, you don't have to worry about the pipe being "next to the hot tranny".
Jesse
Old Oct 18, 2002 | 04:58 AM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
at least someone agrees with me and deezo. obviously i'm biased i won't lie. but Deezo was saying all this on sunday. radiator=hot, bends=bad
Old Oct 18, 2002 | 05:14 AM
deezo's Avatar
...and not saying that there isn't a gain from using it, but where is it getting its cold air from?
Old Oct 18, 2002 | 05:52 AM
Sprint's Avatar
Hey now.. my ***** bends and the ladies say its very effective when the times get hot
Old Oct 18, 2002 | 06:00 AM
deezo's Avatar
Damn that's bad. Hope its only one curve because if you had 2, I'd say you need surgery.
Old Oct 18, 2002 | 06:01 AM
Sprint's Avatar
Old Oct 18, 2002 | 06:06 AM
Blu's Avatar
Blu
the tits
OT but is that frankenmans car in your sig along with yours?
Old Oct 18, 2002 | 06:11 AM
Sprint's Avatar
Old Oct 18, 2002 | 06:12 AM
deezo's Avatar
Old Oct 18, 2002 | 06:17 AM
Blu's Avatar
Blu
the tits
Old Oct 18, 2002 | 06:19 AM
Lime's Avatar
This thread is pointless and a half. Do a search on the CAI versus hybrid.
Old Oct 18, 2002 | 06:23 AM
SR20DEN's Avatar
VQ Wizard
