Apexi SAFC Vs Fields? installed Apexi and speed limiter is still there :(
Old Oct 18, 2002 | 08:34 PM
JAY25's Avatar
I installed my Apexi SAFC, Thanks to SMX (Wayne) and Bosco, for lending me a good hand.
Now for the question why is it that the Apexi SAFC does not over ride the 120 MPH speed limiter and the Fields controller does? can anyone answer this question. Y2Kev you told me this would not work and you were correct. What if I start doing the fuel adjustments which of course that would not be a good idea? I did two runs up to 120MPH and the car just shut down. Tomorrow I will go to Radio shack and manually control that since speed limiter is still there and do the Bens ECU mod. Sprint Ill be hitting up your site for directions since theres about 70 wires and I did see more then one pink wire.
Kevin the reason why I thought this Apexi SAFC would over ride the ECUs signals is becuase after you install the SAFC if you dont program it it will shut your car down. Bosco did some adjusting to that gadget which I still have no clue what he did therefor the car would not shut down.
Old Oct 18, 2002 | 09:02 PM
SkylineGTR's Avatar
its the APEXi RevSpeed Meter that eliminates the speed limiter.
Old Oct 18, 2002 | 09:06 PM
JAY25's Avatar
Apexi rev speed meter? whats that? seriously
Old Oct 18, 2002 | 10:27 PM
SkylineGTR's Avatar
its another one of those gadgets that APEXi makes, it doesnt really DO anything, the AFC adjusts fuel and such, but the RSM doesnt really do anything performance wise, its more of a device to observe things about the car, such as rpms and speed. Also comes with an optional G Meter, and u can calculate things such as 1/4mile like GTech, and 0-60 and how many Gs u can pull etc etc etc. But the biggest thing it does is eliminate the speed limiter on most japanese imports. Y2KevSE has this if im not mistaken and he could probably tell you more of the specifics that the RSM does. Hope that helps.
Terry
Old Oct 19, 2002 | 08:22 AM
JAY25's Avatar
thanks for the input. Kevin doesnt have a speed limiter on his car, I am under the impression he has a SE and those dont come with speed limiters. If he sees this post he will let us know. I am going to do the cut the pink wire. I already cut a wire to install this SAFC so why not cut another one.
Old Oct 19, 2002 | 08:49 AM
Sprint's Avatar
Originally posted by Y2KevSE
Stillen changed the design of their superchargers kits because they realized that leaks or busted MAF sensors can occur if it is after the SC/before TB.
http://64.252.156.63/tails/bensecumod.htm
Old Oct 19, 2002 | 09:02 AM
JAY25's Avatar
thanks for that link, what model switch to I have to get from Radio shack?
Old Oct 19, 2002 | 09:10 AM
Sprint's Avatar
i think Ben said a 20amp switch.. i am switch less.. i like the yellow light
you said you got the Fields.. the Fields killed delio's limiter i think.. so check with him also
Old Oct 19, 2002 | 09:16 AM
JAY25's Avatar
the Fields AFC kills the limiter but I got the SAFC since I am not planning on spraying. But fck it cant have the best of both worlds so Ill go get me a 20amp switch and when game time rolls around switch on for a couple of secs. Thanks for your help
Old Oct 19, 2002 | 09:57 AM
sx7r's Avatar
Re: Apexi SAFC Vs Fields? installed Apexi and speed limiter is still there :(
when you install the Apex SAFC, you don't cut the speed sensor wire, you just splice into it; therefore, the SAFC cannot alter the signal but it can only read it.
but on the Fields sfc, you cut the speed sensor wire and input into the Fields and then the unit alters the signal and feeds the altered signal to the ECU.
Old Oct 19, 2002 | 10:48 AM
nismo2020's Avatar
Needs non-Maxima Friends
IIRC all 5th gens regardless of model, autos had limiter of 130 something mph.
Old Oct 19, 2002 | 11:08 AM
mtrai760's Avatar
'Trynna' is not a word
Kev also has the Apexi RSM, which cut's his speed limiter...
Old Oct 19, 2002 | 11:21 AM
JAY25's Avatar
Re: Re: Apexi SAFC Vs Fields? installed Apexi and speed limiter is still there :(
So this means I cant cut the wire then? since I tapped into it? I have to go check to make sure I didnt tap into this pink wire. If I did then I am stuck at 120 for ever. Ill check on the Apexi RSM then. You answered the question perfectly thanks.
Old Oct 19, 2002 | 11:37 AM
SkylineGTR's Avatar
kevin had SE, but it was automagic, and all automagic 5th gen has limiter @ 130mph, ive tried going past it, just doesnt go anywhere
Old Oct 19, 2002 | 02:35 PM
Maxima06071
Mine stops at 120mph
Old Oct 21, 2002 | 09:30 AM
Bags's Avatar
VG Ridah's Biatch Hoe
let me know if your dynoing anytime soon or if there is anything i can help with
Old Oct 21, 2002 | 11:43 AM
djPlayboy's Avatar
ive got a auto 5th gen and mine doesnt quit till close to 140
Old Oct 21, 2002 | 11:48 AM
Sprint's Avatar
the way i understood it.. the first model 5th Gen's had limiters and the late ones didn't for 2000.. i am not sure..
Old Oct 21, 2002 | 01:13 PM
Regime's Avatar
The non-postwhoring Org member
I have hit my limiter at approx. 139mph too on my 2001 AE. Pulls and pulls...then just shutters a little and stops accelerating.
Old Oct 21, 2002 | 02:56 PM
Chebosto's Avatar
RIceD OuT moDErAtor
who ever said anything about the SAFC cutting the speed limiter?
man, i hope you double check these things prior to installing them.
yea. its the Rev/Speed Monitor that disables your speed limiter, but will give you a check engine light for auto-tranny link, 0504 (?? i think)
well anyhoo. if you want to get rid of your limiter, just get an SE ecu.
Old Oct 21, 2002 | 03:03 PM
JAY25's Avatar
I was under the impression it would cheston but it didnt. I did get two CE codes because it came on as me and SMX went on a friendly run. I can cut the wire and I will use the 20 AMP switch to turn on briefly. I wonder how much a SE ECU will run me?
Old Oct 21, 2002 | 03:15 PM
Chebosto's Avatar
RIceD OuT moDErAtor
ecu costs around $120-150.
no big deal
do it right and get no codes.
Johnny9595
Sep 3, 2015 05:18 AM
Lowered_a33
Sep 1, 2015 07:49 PM
umnitza
Sep 1, 2015 01:03 PM
TurboA32
Aug 27, 2015 08:44 AM
t6378tp
Aug 24, 2015 07:03 AM
