First the engine, then the transmission
Old Oct 20, 2002 | 08:54 PM
BrianV's Avatar
Yeah lost the transmission tonight.
Second to third gear shift and that was it.
Car won't go into first or second gear at all now and was making horrible sounds when rolling.
Who's replaced a transmission, what do they go for at the junkyards, and what does Nissan charge for their rebuilt transmissions. I may go through insurance because I was in an accident very recently that involved physical damage to the transmission's external casing.
Old Oct 20, 2002 | 08:58 PM
SWEETSOUND2001's Avatar
I30t or Maxima ES tranny with LSD if you're swapping the tranny...
Sorry to hear that
Old Oct 20, 2002 | 08:59 PM
BrianV's Avatar
Sorry to hear that
Can I buy that from Nissan? If this other company's insurance is repacing it then they will buy a remanufactured one from Nissan.
Old Oct 20, 2002 | 09:05 PM
Yes and you'll also have to buy LSD driveshafts (stronger). I don't see a problem with this since this will be an OEM tranny. BTW, Don in Texas sells heavy duty drive shafts so you should hit him up.
Old Oct 20, 2002 | 09:06 PM
dmontzsta's Avatar
Ford Only.
Yes you can get that from the dealer. You already have the infiniti motor, you might as well get the LSD trans to match.
Old Oct 20, 2002 | 09:07 PM
BrianV's Avatar
What year I30t transmission's have the LSD?
I assume these are easier to find the ES Maxima from Canada.
Anyone have a part number on the transmission I need, and is driveshafts the only other part i need?
Old Oct 20, 2002 | 09:29 PM
ericdwong's Avatar
I really hate nissan transmissions.
Old Oct 20, 2002 | 09:30 PM
BriGuyMax's Avatar
The LSD trannys are REALLY hard to find. Your best bet if you really want an LSD tranny is to find a 95-99 I30T 5-speed trans. They ALL have LSDs.
You don't need both drive axles if I remember correctly. I think you just need the drivers side axle.
Nissan doesn't sell re-built transmissions for our car unfortunately.
Junkyard prices vary...just look around and find a good deal.
Old Oct 20, 2002 | 09:35 PM
BrianV's Avatar
Then they sell new ones, if I go through insurance then that's what insurance will have to buy, insurance doesn't pay to rebuild things, it's a risk to them, it's gotta be done the right way.
If I pay for it, i will buy one from the junkyard. What's the price on these things typically? Also, I think it's the passenger side axle that needs to be changed.
Old Oct 20, 2002 | 09:38 PM
dmontzsta's Avatar
Ford Only.
You should be able to get a used one for under $1k. thezcarguy just had his trans rebuilt and a new clutch put in for $1100
Old Oct 20, 2002 | 09:40 PM
NYCe MaXiMa's Avatar
same here.
Excellent engines
but terrible trannys
sorry to hear that Brian
i know the feeling
Old Oct 20, 2002 | 09:41 PM
BriGuyMax's Avatar
New ones are like 4 grand....hahahahaha
You can probably get a trans from a junkyard for 600-700 bucks.
Maybe it is the passenger side axle....I didn't know so I just bought a quaife
Old Oct 20, 2002 | 09:43 PM
BriGuyMax's Avatar
I got my trans re-built for $300
I had to take out and put it back in myself though
Old Oct 20, 2002 | 09:44 PM
MAXINXS's Avatar
I have had 2 transmissions go out on my Maxima. The first time I bought one from a junkyard. It ran $1600 dollars installed by Nissan. The second time I had that transmission rebuilt. I paid $1400 for the new bearings, differential gear etc. (replaced everything internally that was broken). If I had to do it all over again, I would go with a used tranny. My transmission is a bich to get into gears now. Like Eric said, I hate Nissans transmissions too! Good luck. Btw- welcome to the "I broke my tranny club."
Old Oct 20, 2002 | 09:58 PM
BrianV's Avatar
We'll see, I keep hearing drastically varying numbers on the price of these junkyard trannies.
I know new ones aren't cheap, but that's how insurance does it. My friend just had to get a new one for his camaro z28 and they got him a new one.
Old Oct 21, 2002 | 06:18 AM
Stephen Max's Avatar
Hi Brian, sorry to hear of your troubles.
A-1 Imports south of Bergstrom has two high mileage manual transmissions for $450 each. (You're still in Austin, right?) They will have to be rebuilt, but they are otherwise in good condition (all gears turn, etc.) They are both non-LSD even though the counter guy was "absolutely positive" over the phone that one of them was LSD. Beware of buying a used transmission sight unseen from junkyards. They will tell you anything to make a sale.
Old Oct 21, 2002 | 07:49 AM
BrianV's Avatar
Due to the fact that there is external casing damage to the transmission, my insurance company is taking care of it. Since insurance comapnies just replace transmissions if they're externally damaged it's not a problem. Regardless of whether the cause was from too much power or from the external damage, the insurance company has to replace it just based on the fact that there is external damage. I guess it really couldn't have happened at a better time.
I also discovered I got a nice size dent in my oil pan.
Old Oct 21, 2002 | 11:14 AM
mtrai760's Avatar
'Trynna' is not a word
Brian, check out www.car-parts.com that's where I found my VLSD with 7k miles for $700.
Old Oct 21, 2002 | 11:59 AM
buss95max's Avatar
every junkyard tells you a part has extemely low miles...
Old Oct 21, 2002 | 01:08 PM
BrianV's Avatar
Is our tranny casing cast iron or aluminum?
Old Oct 21, 2002 | 01:15 PM
Aluminum.
Old Oct 21, 2002 | 01:16 PM
BrianV's Avatar
Aluminum.
Thanks for the quick reply
BTW, dealer cost of 5spod nissan tranny is $27xx and i30t with vlsd is - $30xx
Old Oct 21, 2002 | 02:33 PM
ericdwong's Avatar
To find out the mileage of the tranny, take the VIN on the tranny and run a carfax on it. If its a junkyard car it will show when the salvage title was issued. My tranny had 16,000 miles on it
Old Oct 21, 2002 | 02:49 PM
Jime's Avatar
Re: First the engine, then the transmission
Hey Brian
Been there done that. If you want to play you got to pay. My engine with 50k cost $900 and the LSD tranny was $800. You are lucky the insurance is coming in there.
They will take a lot of punishment but there is a limit. When you test it eventually you will find it.
I am not sure experience is worth the price but you do learn.
Jim
Old Oct 21, 2002 | 02:50 PM
BriGuyMax's Avatar
The dent is probably from when your new motor was sitting waiting to be installed...mine is dented too. It won't hurt anything unless it's leaking.
Old Oct 21, 2002 | 03:06 PM
nismo2020's Avatar
Needs non-Maxima Friends
my oil pan is dented too. it happened when i shipped my car.
i think they smacked it when they drove it onto the truck.
Old Oct 21, 2002 | 03:16 PM
BriGuyMax's Avatar
dumbasses
Old Oct 21, 2002 | 03:19 PM
Sprint's Avatar
http://www.car-part.com
Infiniti I30
MT - non-locking diff
make sure they read off the code to you so you know its LSD
Old Oct 21, 2002 | 05:41 PM
The last digit should be V for VLSD.
Old Oct 21, 2002 | 06:49 PM
mtrai760's Avatar
that's why you run a VIN check and find out how many miles were reported on the car when it was wrecked...
Old Oct 22, 2002 | 06:51 AM
BrianV's Avatar
The oil pan came off my old engine, it isn't dented, and the dent is shapr and deep from the driveshaft, the shop thinks it may have gone 1/2" to 1" in a caused a slow leak, but they just got a look at it.
I don't think I punished my tranny too hard, I never did speed shifts or anything, it was always full clutch in, full clutch out, etc. I think somehow it got low on fluid.
derekinthez
Nov 13, 2022 04:00 PM
sctludwig
Sep 1, 2022 01:32 PM
seesole
Sep 14, 2015 12:38 PM
I<3 A32's
Sep 10, 2015 11:07 AM
videomano
Sep 8, 2015 03:28 PM
