Y-pipe/ ECU question
Old Oct 21, 2002 | 08:49 AM
RidinALowMax2's Avatar
Hell yeah.....i finally got confirmation from Warpspeed this morning that my TIG SS y-pipe should be getting here tomorrow. I have been waiting for it since Sept. 10.
anyways......the question is.....when i put the y-pipe on, do i have to reset or do anything to the ECU? Will resetting the ECU cause it to better regualate the new, higher flow of air? I know, I know...use the search button. But i figured a quick answer from you guys is better. Later
Old Oct 21, 2002 | 12:36 PM
Nealoc187's Avatar
SLOW
No. Some people believe you do, but I disagree with that theory. I have never reset my ECU after any of my mods.
Old Oct 21, 2002 | 01:27 PM
maseo77's Avatar
resetting ecu?
if you dont reset your ecu, after driving for a little while(depending on the mod)the ecu will eventually "learn" the mod and adjust accordingly. if you do reset after the mod the ecu will "learn" much quicker and adjust much faster.
Old Oct 21, 2002 | 08:22 PM
Victim64's Avatar
Yep, if you reset your ECU, it will learn to change the preset WOT map.
or maybe closed loop has a meaning??
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
junito1
Sep 23, 2015 12:14 PM
Socalstillen
Sep 20, 2015 11:46 PM
QueensMAX
Sep 15, 2015 04:14 AM
