what tire psi is best for wet weather?
Old Oct 25, 2002 | 12:21 AM
Soon2BMaxed's Avatar
i was just wondering
Trevor
Old Oct 25, 2002 | 03:40 AM
wdave's Avatar
Re: what tire psi is best for wet weather?
Trevor
The tire manufacturers say keep the pressure high to keep the tread grooves open. It makes sense and seems to work, certainly it did for road racing.
Old Oct 25, 2002 | 06:36 AM
njmaxseltd's Avatar
Re: Re: what tire psi is best for wet weather?
Higher tire pressure will reduce your contact patch. Reduced contact path means less rubber on the road. Less rubber on the road means you will lose traction quicker.
Please refer to the sticker in the center console arm rest for proper tire pressures. A few pounds higher (2or3) especially if your on lower profile tires is probably still acceptable. This value should be set when the tires are cold, usually first thing in the morning before you drive your car.
Old Oct 25, 2002 | 09:23 AM
wdave's Avatar
Re: Re: Re: what tire psi is best for wet weather?
Smaller contact patch in rain is good - less aquaplaning. However, I didn't say raise them sky high, I just said KEEP them high.
Old Oct 25, 2002 | 03:52 PM
Chebosto's Avatar
RIceD OuT moDErAtor
90 psi.
so you can float.
j/k
i'd prolyl do like 33, u want more patch on the ground. might i suggest RE730s.. very good wet weather traxion.
Old Oct 25, 2002 | 03:56 PM
deezo's Avatar
Keep your tires at normal operating pressure (32-35 psi). Mot tires are designed to perform optimally at those ratings.
Old Oct 25, 2002 | 05:07 PM
thanks fellas!
aw11power
Oct 10, 2021 04:57 AM
TKHanson
Nov 24, 2018 01:39 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
