Optima battery
Old Dec 26, 2000 | 09:51 AM
1MAX2NV's Avatar
Ok..my battery went dead this morning. I'm debting between getting the regular green top Interstate battery or the Optima. The maxima takes MT-35, which is a reverse post. The Optima's post are the standard. Now, my question....people that are using Optima, does your cable reach??
Old Dec 26, 2000 | 10:20 AM
Jeff92se's Avatar
I'm needing a caw
Tony does Don't sig pic help??
<img src=http://home.swbell.net/dgcoop/enginegreen.jpg>
Old Dec 26, 2000 | 10:53 AM
1MAX2NV's Avatar
Thanks Jeff. It did. I went out and check my cables and I think they will reach. I found the Optima locally for $119, which is a really good price. Time for me to head out and buy the battery.
Old Dec 26, 2000 | 11:52 AM
1HOTMAX's Avatar
where for $120???
hey tony, where did you see it for 120???? in nyc??? i live in flushing any idea where i can get one for 120? ask to see if they give us a break on 2 cause i need one bad
Old Dec 26, 2000 | 12:01 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: where for $120???
there's a local distributor in Astoria. i dunno where it is but you'll have to look in the phone book. ask then how much and see if they can cut u a break on the price.
Old Dec 26, 2000 | 03:34 PM
ereet's Avatar
Nope,
Mine didn't reach. I had a piece of board under the battery to "raise" it to the level of the black-top piece in the middle of the battery holder. After that, the cables wouldn't reach anymore. Sooooooo, what I did was remove the bottom piece, and cut out a riser pad which I put under the black bit. It looks pretty tacky and I'm going to be just adding shorter screw lengths so I can fit it on properly, but for now, it works, and the cables fit.
Old Dec 26, 2000 | 04:49 PM
Mike S.'s Avatar
My battery....
My battery is still not clamped down.....I lost the brackets when i installed it cuz at first they wouldn't fit. Hmm....I wonder if the brackets whet the way of my K and N pannel.....IN THE GARBAGE If its not nailed down my mom will throw it out!
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
markevans999
Sep 10, 2015 04:29 PM
