heat wrap for exhaust? works?!
Old Nov 6, 2002 | 06:00 PM
Maxima90SE's Avatar
has anoneone put heat wrap on their y pipe or headers?? it says it works but i dunno?? anyone does??or has? maybe even putting it on CAI to keep the air cold in it??
Old Nov 6, 2002 | 11:43 PM
K Pazzo 6's Avatar
Re: heat wrap for exhaust? works?!
Old Nov 7, 2002 | 02:32 AM
thnikkamax's Avatar
Ludicrous Speed
Hmm...ask that one guy that recently introduced a new turbo kit for the 4th gen. I think he used heat wrap for the piping. Theoretically it should work.
Old Nov 7, 2002 | 08:06 AM
acMAX's Avatar
I was thinking of doing this to my y-pipe to reduce the sound....
I'm pretty sure Y2KevSe had his supercharger tubing wrapped
when he had it.
Old Nov 7, 2002 | 08:09 AM
hlh0501's Avatar
I used it on my return cold air from the intercooler... still debating if I want to do that or powdercoat as powdercoating is the obvious "prettier" answer...
Old Nov 7, 2002 | 09:04 AM
Street Reeper's Avatar
Handsome
Chevy uses it on their corvettes. But it is there to heat up the pipe so the cats will warm faster. Hot cats reduce emissions, if chevy didn't have this they would have to put more cats on that would sacrifice power. A simple engineered way of getting more power with low emissions.
Old Nov 7, 2002 | 09:35 AM
JAY25's Avatar
Kevin had it on his crossover pipe to keep the heat off the pipes. I use a CAI DEI cover on my cross over pipe to keep the pipes as cool as possible. All you NA guys with CAI will benefit from this cover. It is a $58 cover. After a 10 minute drive pop your hood and touch the metal CAI tubes, careful they are a bit warm. That is what the DEI CAI is for to keep the temp a bit cooler. As far as wrapping the Ypipe I dont wrap my Y pipe so that answer I can give you.
Old Nov 7, 2002 | 09:37 AM
redmaxpa007's Avatar
i SeE what you did therE
i thought about getting one of those when i an not showing the car..
(everyday drving)
Old Nov 7, 2002 | 11:01 AM
Stephen Max's Avatar
On turbocharged cars heat wrap is used on the exhaust pipes leading to the turbo so that heat energy is retained in the exhaust. You don't want the exhaust gases to contract as they cool off until after they are run through the turbine. In SCed or NAed cars it has no use on the exhaust except for keeping heat out of the engine bay or allowing the cat to operate hotter.
As far as intake pipes are concerned, if you're NA, then maybe heat wrap will keep engine bay heat from soaking into the intake pipe while stopped, but the engine bay doesn't get that hot when you are moving and air is circulating. In turbo or SC sitatuations, I believe heat wrap can hurt you because it prevents heat from escaping the heated, compressed air between the blower and the intake. The question is whether the intake air is hotter than the engine bay air. If it is, then heat wrap hurts you.
Old Nov 7, 2002 | 12:13 PM
JAY25's Avatar
Re: Re: heat wrap for exhaust? works?!
I popped my hood many times after rolling on the highway as you just posted and the pipes were hot. Also when my car is cool and I warm up the engine and proceed to run someone within minutes I can feel the difference in performance when the pipes are cooler then when they are hot. The wrap that I have has some type of fiberglass built into it and is not as hot as the pipes usually would be.
Old Nov 7, 2002 | 01:14 PM
Re: Re: Re: heat wrap for exhaust? works?!
When I install my SC I'm going to also install an intake air temperature gauge and take measurements between the filter and blower and between the blower and the throttle body. Should be interesting.
Old Nov 7, 2002 | 03:44 PM
96BLUMAX's Avatar
I have my ypipe wrapped and it works well, not that i know the difference between that and not wrapped. It also makes it better when working under the car after it has been running. Less burns from hot a$$ ypipe.
JRod28
Dec 29, 2023 09:56 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
jerrod99_se-l
Aug 17, 2015 06:23 AM
98nismomax
Aug 13, 2015 12:15 PM
kenc15
Aug 5, 2015 08:29 AM
