Need help with wheels- offset and spacers
Old Nov 9, 2002 | 05:35 PM
Nismo's Avatar
I have some 18x7.5 wheels with a 48mm offset. I want to get spacers for them and I was thinking about 15mm spacers all around which would make it to a 33mm offset, how would this look perform? I dont know if I should get 5mm or the 15mm spacers. I would be using 235/40/18 tires with them. any help would be appreciated.
Old Nov 9, 2002 | 06:22 PM
Nismo's Avatar
Im also thinking about just getting 5mm spacers all around making the totak offset to be 43mm. any input is appreciated
Old Nov 9, 2002 | 07:08 PM
carnal_c30's Avatar
Former Sponsor
my guess is that it will fit fine, if you go 15 in front you might want to do the same in the rear
you'll need longer studs I'm sure you know that.
if you go five all around thats pretty close to the stock offset I think, the only reason I would consider running 15mm spacers is to clear brakes, but I'm sure it should be ok.
CalsonicSE runs 15/20mm spacers all around, I dont think he has had any problems
Old Nov 9, 2002 | 07:40 PM
Nismo's Avatar
I thought the H&R spacers come with the longer studs? if not then do you know any sites that carry them? the only reason I was thinking about 15mm spacers is because I dont think they have 10mm which I want because it will then put my in the ideal 38mm offset. My research says that 43mm would work good without rubbing issues but I am just wondering how would a 33mm (15mm spacers) would look? would they be too close the the fender? im confused right now
Old Nov 9, 2002 | 07:41 PM
Nismo's Avatar
also since the h&r spacers are hubcentric, does that mean I still need to get the hubcentric ring for my new rims? or do the spacers take care of that?
Old Nov 9, 2002 | 09:53 PM
carnal_c30's Avatar
Former Sponsor
I think the spacers will take care of it- I dont use rings I run 10mm spacers (two 5mm plates together)
Old Nov 9, 2002 | 10:04 PM
NYCe MaXiMa's Avatar
i thought the wheels you got fit 4th gens without any spacers?
ask other people who have them on 4th gens, there are a few..
Old Nov 9, 2002 | 10:11 PM
Donkey®'s Avatar
wat
If you order H & R spacers, 5 or 15 mm, they come with longer studs. I needed spacers as well, but, I thought 15mm was just too big. So, I took some 5mm H & R spacers to a machine shop and had them make me 10mm spacers out of aluminum. They are perfect. The wheel does not protrude at all out of the wheel well and because they are hubcentric, I don't get any wheel wobble. In my opinion, that is the way to go.
RinconI30
Jun 11, 2016 08:25 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
