Busted Flex Section?
Old Nov 10, 2002 | 09:06 PM
Aaron's Avatar
Langley AFB Sux
Can someone who has had this describe the sound for me? My ypipe makes a slight rattle for like 3 seconds when you rev the motor. Doesnt do it all the time. I'm thinking the lining is bad?
Aaron
Old Nov 10, 2002 | 09:09 PM
nymjayjay's Avatar
Re: Busted Flex Section?
Aaron
what kind of pipe?
Old Nov 10, 2002 | 10:32 PM
Aaron's Avatar
Langley AFB Sux
Re: Re: Busted Flex Section?
Originally posted by nymjayjay
what kind of pipe?
budget. I'n not so sure this is the problem. It could be a loose bolt or bracket. I'm going to get under it tomorrow and see if I find anything.
Aaron
Old Nov 10, 2002 | 10:35 PM
Nismo's Avatar
how long have you been hearing it? do you see any black soot on the outside of the lining? check to see if any of the flanges are loose too.
Old Nov 10, 2002 | 10:37 PM
Aaron's Avatar
Langley AFB Sux
Just started this evening. Pipe has been on around a year with no problems. I dont see any soot or anything.
Old Nov 10, 2002 | 10:58 PM
Nismo's Avatar
humm, well I would start by jacking up the car and starting it and try to feel if you feel or hear any air leaking out of anywhere on the whole exhaust to try to iscolate wherever its comming from.
Old Nov 10, 2002 | 11:40 PM
kj043's Avatar
i have a similar problem with my year old budget pipe, but haven't had the chance to get under the car to diagnose exactly where its from yet. I have a good feeling its from the flex though. a replacement lined flex from wsp is around 55 shipped. tell me how it goes after you take a look.
Old Nov 11, 2002 | 05:48 AM
95Max's Avatar
When my cattman had a bad flex I didn't notice a noise so much as a lack of power when you floor it. No way for the exhaust gas to escape.
Old Nov 11, 2002 | 11:51 AM
Aaron's Avatar
Langley AFB Sux
Wierd.........comes and goes.....then when trying to pinpoint it...it stops....grrrr. No power loss yet.
Maybe some heatshield is loose somewhere or something.
Old Nov 11, 2002 | 12:02 PM
95Max's Avatar
Your comment about the heat shield reminded me that when I have the pipe installed I needed to bend the heat shield away from the pipe. Get under the car and look up you will see what I am taking about.
Good luck
Old Nov 11, 2002 | 01:18 PM
Aaron's Avatar
Langley AFB Sux
Good luck
Is there heatshield on the car where the pipe runs up the the manifolds? I cant remember. I check around the cat last night and it all seemed tight.
Old Nov 12, 2002 | 04:42 AM
95Max's Avatar
There is a heat shield were the pipe runs up to the manifold. Trying to remember here....I think the heat shield that I bent was the one that is next to the 2nd up (the one closest to the rear).
Old Nov 12, 2002 | 05:09 AM
Aaron's Avatar
Langley AFB Sux
Gonna look today.....crappy weather last nite.
Hmmm it started right after i missed 3rd against a boosted eclipse. I think i'd of had him if i didnt mis-shift. Off the bottle.
Aaron
Old Nov 12, 2002 | 06:14 AM
Jamsan's Avatar
be glad you were off the bottle when you missed that shift
if you havent orginally bent the heat shield near the cat out of the way, that could be it...havent seen any heatshields near the manifold, but then again i havent really looked....also, try driving along side of a wall or metal barrier, i.e. on the highway, and give it light throttle, and have your windows open...the sound will bounce off the wall/barrier, echoing louder, so you can see what it really sounds like
Old Nov 12, 2002 | 07:02 AM
Aaron's Avatar
Langley AFB Sux
Yeah no kidding.....although as soon as the tps loses voltage (not at WOT anymore) the zex supposedly wont spray....im thinking there is a delay tho......regardless i dont want to find out
Ne way my front bumper was at his rear....rolling start...think he got the jump on me. It was a friendly meeting. The guy has a nice eclispe....total sleeper...no badges or markings....stock wheels....only signs are the boost gauge on the pillar and the lovely bov sound
Yeah......it seems to me that if it was the flex section it would do it all the time.
Aaron
Old Nov 12, 2002 | 07:56 AM
Jamsan's Avatar
Aaron
your right on that...it most likely is something banging against something else....just look for any kind of heat shields that might be in the way of the pipe when it moves around
KabirUTA13
19
Oct 17, 2015 02:15 AM
asianstyle
Sep 10, 2015 11:30 AM
