Re-doing my dual exhaust setup, need everyones help and input
Old Nov 17, 2002 | 10:54 PM
Craig Mack's Avatar
All YOUR grammer belong to me
After 11 months of my current setup, I am ready to move on. My exhaust is starting to annoy the heak out of me. I was originally going to slap a resonator or 2 in the system but I don't think that'll cure my problems. I think my problems lie in my muffler. It's a flowmasters 40-series...it's flowmasters loudest muffler available. It sounds nice at idle and what-not, but when I go WOT it sounds unbelievably ricey. My current setup is a WSP Y-pipe --> Stock Cat --> 2.5" b-pipe w/no resonator -->Flow 40-series --> 2.25" pipe running around spare tire well for a fake dual setup. I think the muffler is the main culprit for the ricey WOT, as the muffler was intended for big V8's, not 6cyl. imports.
I have been looking at the Flowmaster 60-series mufflers, that are made for 4 and 6cyl. imports. Check out the sound comparison between the 60 series and the 40 series:
60 Series
40 Series
I have been thinking about getting two 60-series mufflers. I already have a pipe wrapping around the tire well, so welding the muffler into it will be easy. But I haven't seen a 60-series muffler with dual inlets, and I need one to have dual inlets so I can hook the other muffler piping into it. If indeed they only come with single inlets/outlets, where can I hook the other muffler piping up to? I realize the spare tire well is going to have to get crushed for this to work, not a problem.
I am worried the 60-series is going to give the car a monotone low hummm like most conventional setups for the Max. On the other hand, I can't stand the rice I get at WOT with my current setup, and want to significantly quiet down my exhaust for when the blower goes on. If I go with two 60-series, I could throw a resonator into the b-pipe as well to really get things quiet.
So what do you guys think? I'm gonna need all the help I can get in planning this little project.
-Craig
Old Nov 17, 2002 | 10:56 PM
nismo2020's Avatar
Needs non-Maxima Friends
do you have to have a dual set-up?
Old Nov 17, 2002 | 10:57 PM
Craig Mack's Avatar
Yes. I already have the cutouts in my bumper and really love the look.
Old Nov 17, 2002 | 11:27 PM
thebigsadler's Avatar
i swear to god, just ignore all my posts.
get 2 high flow resonators for like $40 a piece and weld them in.. guarranteed to fix it.. you can try one and then try a second..
Old Nov 18, 2002 | 07:10 AM
Dave B's Avatar
Not DAVEB the parts guy
I agree, get a big resonator in there. I've got the Stillen B-pipe with no resonator teamed with the stock muffler. I'm getting a resonator installed because I don't like the harsh and metallic sounds of the exhaust, especially when cold. I can only imagine how bad your's sounds with the Flowmasters.
Dave
Old Nov 18, 2002 | 09:03 AM
96BLUMAX's Avatar
Yeah I noticed a huge difference between my bpipe with resonator to the one without.
Old Nov 18, 2002 | 10:40 AM
SuDZ's Avatar
Gotta agree with them here. I mean try it out and if you dont like it then at least when you swap mufflers it is still not ridiculously loud. It will clean up the sound a lot.
SuDZ
Old Nov 18, 2002 | 10:48 AM
deezo's Avatar
I'm think people don't like Craigy anymore...
Old Nov 18, 2002 | 12:16 PM
Craig Mack's Avatar
Dude, settle down...I don't ignore your posts. I just have high doubts about resonators. For example, WizzaMax stuck a 22" Allied Resonator in his b-pipe (supposedly the quietest brand) and he said it decreased his sound by 10%. That's nothing IMO. I'm looking to cut out the rice at WOT and in the higher RPM band.
Dave, I actually love the sound I get below 2k rpms. I need to get a video up sometime. It actually sounds better then alot of Camaro V8's I've heard. It would blow away a Camaro with loudmouths. But whenever I floor it, it sounds so unbelievably ricey that I now avoid doing it. I wish they had some kind of variable resonator that wouldn't effect low end sound but would get rid of the rice when going WOT and in the higher RPM band.(2000+) The tone of the exhaust is so different when going wot it's amazing.
I am willing to stick as many resonators in the pipe as I can, but space is cramped for the b-pipe...I don't think you can just slap a few resonators in there and call it a day.
Old Nov 18, 2002 | 12:36 PM
Kashoggio's Avatar
just straight pipe it all
I am going to cahnge my set up as well. some thing like the bigsadler's set up... just dont know what kind of mufflers to go with.. time will tell
Old Nov 18, 2002 | 12:48 PM
Craig Mack's Avatar
Originally posted by Kashoggio
just straight pipe it all )
Old Nov 18, 2002 | 02:25 PM
SuDZ's Avatar
Originally posted by Craig Mack
the guy I bought my 2k2 Muffler off of went with straight pipe. He went from a Y pipe setup to test pipe to straigh back to B pipe and to no muffler. He had no resonators along the way.
That must have been loud and sounded like crap.
SuDZ
Old Nov 18, 2002 | 02:27 PM
Redmax's Avatar
Redlinemax Owner
but do the resonators slow down the air flow
Old Nov 18, 2002 | 02:38 PM
Craig Mack's Avatar
They will some, but it will be very insignificant.
Old Nov 18, 2002 | 03:02 PM
SuDZ's Avatar
I doubt you would notice it any.
SuDZ
Old Nov 18, 2002 | 03:31 PM
he tried an allied huh? are they high flow?
you need 2.. one on each exhaust pipe.. you have that flowcrap bullshtt on there and expect it to sound good at high rpms.. either get mufflers, or slap some res' on there..
you don't know anything about it because you haven't tried anything yet.
Old Nov 18, 2002 | 03:33 PM
Jeff92se's Avatar
I'm needing a caw
Two 2000+ maxima mufflers, no resonator needed probably.
Old Nov 18, 2002 | 04:02 PM
Craig Mack's Avatar
Wheres the puke smiley when you need it? If I get 2 mufflers, they will be the 60-series flows.
Sadler, you think if I get a small resonator on my dual pipe (that wraps around the tire well) and a BIG one in my b-pipe, that my car will be significantly quieted? Well, i'll definatally go down there and ask them what they thing about it. It's just when Wizza said one of the bigger quietest resonators took only 10% off, I got a little dissapointed. I guess I should think differently?
Old Nov 18, 2002 | 05:58 PM
95emeraldgxe's Avatar
have you heard the car from the outside at WOT??
Old Nov 18, 2002 | 06:01 PM
What size exhaust does he have, and what all other than a b-pipe does he have.. what is the allied res like?
You need a res that deepens the tone and quiets at high rpms, they make such things.
Craig Mack's Avatar
Ya, I've let people drive it and have a video if me driving it...it's horrible.
Old Nov 18, 2002 | 07:22 PM
JAY25's Avatar
not to clown you but why do you want two exhausts vice one?
Does your neighborhood have lots of Rized out Hondas
have you noticed HP gains share
Old Nov 18, 2002 | 08:13 PM
SuDZ's Avatar
He likes the look and sound at idle.
SuDZ
Old Nov 18, 2002 | 09:10 PM
nismo2020's Avatar
jeez why do you insist on putting them flowmasters on there! just because its name is flow master that doesnt mean that it does.
you kill me with your quest for the "v-8 mustang v-8 camaro dual exhuast"
Old Nov 18, 2002 | 09:58 PM
Old Nov 18, 2002 | 10:27 PM
Jeff92se's Avatar
I'm needing a caw
Well, good luck with your exahust sound then. From what I see/hear, the flowmasters are loud. They sound good on a V8 because as you know, they have the displacment to make the tone low and nice. You know you could put any tips you wanted on those mufflers. I really don't see anyway of quieting down the resonating w/o changing out to maxima or maybe Borla mufflers.
I had the feeling those duals were gonna get on your nerves sooner or later.
Old Nov 18, 2002 | 11:00 PM
ereet's Avatar
SC made my exhaust note quite a bit deeper. You might want to check that out first. If it does make it sound better, you'll know wether or not to cut out the muffler completely and get a new one, or just try to quiet the one you have right now down a bit more (and probably cheaper I might add) with acouple of resonators.
Old Nov 18, 2002 | 11:26 PM
Frank Fontaine's Avatar
I think it's for the look, not the HP. Probably there is a HP loss due to the setup. It's not that simple to bolt-on HP. There was a time when we all fell for the "2-5 HP gain" with the K&N Panel. I know I plunked down the $48 plus cleaning kit!
Old Nov 19, 2002 | 04:23 AM
Kashoggio's Avatar
Old Nov 19, 2002 | 05:21 PM
Craig Mack's Avatar
How does the supercharger deepen the tone?
JAY25: Becuase duals look MUCH better then single exhausts. Especially on a car like a Max that doesn't come with them. Custom, unique, and aggressive. I can't count how many compliments i've gotten on my exhaust. Steam pouring out of both tips on a cold morning is priceless.
Nismo2020 See above.
Jeff92SE, I totally forgot about transferring the tips! 5th gen mufflers might just be the way to go. But wouldn't they make my sound TOO quiet? I mean I still want it to have that deep rumble at idle, I just want the loud blaring rice sound to vanish while accelerating. Would I keep a similer idle sound with 2 2000 max mufflers over my flow? And why do you recommend the 2k mufflers instead of the 4th gen mufflers?
The only problem with the mufflers is the piping. My flowmaster has dual outlets so the pipe wrapping around the tire well connects to it. If I get two stock mufflers, what am I going to do? where am I going to hook the second muffler up to? I also have a feeling that what ever it is, it's going to be expensive.
Old Nov 19, 2002 | 07:16 PM
JAY25's Avatar
Hold up wait hold up, I know you are not trying to even clown, you know your ride sounds like a V12 , We can hear your viper from 2 miles away
Craig you know we just clowning on you we need a good laugh sometimes. Clown Nismo2020, I bet you cant hear your duals if you dare to race him. He got me beat with the V12 deep tone.
Old Nov 19, 2002 | 08:04 PM
nismo2020's Avatar
my set up is too loud too. sometimes i love and the next minute i hate it. i have this lying around so i might change it out
Old Nov 19, 2002 | 08:41 PM
96BLUMAX's Avatar
I really like the sound from my borla muffler. They also make the right size for you too. Also they sell resonators as well. Check out their site.
Old Nov 21, 2002 | 11:46 AM
Craig Mack's Avatar
If his exhaust is louder then mine, it must be ricey as hell at WOT! I know I can't stand mine. It's a love hate deal - Love it at idle and creeping, hate it while driving spiritedly.
No one has answered my question about the 2k stock mufflers. Why and how loud would it be vs. my current setup? I want some flow 60 series or borlas, but they are too expensive...and I know Cbr2 could get me a really great deal on stock mufflers, so that route looks more appealing. But how would it sound?
Old Nov 21, 2002 | 12:06 PM
Cumalot's Avatar
Got your SC yet Craig?
Old Nov 21, 2002 | 12:10 PM
KLoWnPR109's Avatar
If you got the stock mufflers, there wouldn't be much to hear. I went from a raspy universal muffler to a 5th gen muffler, and all I hear now is a slight growl while slowly accelerating
Old Nov 21, 2002 | 12:38 PM
JAY25's Avatar
Ricey is not the word to describe his shyt! How about you needs some ear plugz if you race him , anyhow he did have a straight pipe and he told us flames was coming out of it. I was just messing with you about this whole deal I know you do it for the looks like Sadler. So I know you dont get no HP gains for those who posted below me I was just messing with Craig.
Old Nov 21, 2002 | 12:40 PM
Craig Mack's Avatar
Nope. CoolKids had to order a new main piping peice and some other stuff from $tealin'. I need to get back in touch with him....I REALLY want that SC! But God knows how long stillen takes to deliver stuff.
BTW, I heard you were selling yours to SeximaGTR! Man, I hope you don't go through your women like you do your mods!
Old Nov 21, 2002 | 12:47 PM
SuDZ's Avatar
it has a nice tone. It will not be loud and rumbly but rather mellow and when you hit WOT it will open up more. I have it on mine and like it, never mind two of them. As far as I go it would be just loud enough but not overkill.
SuDZ
Old Nov 21, 2002 | 01:57 PM
