Bellhousing question
Old Nov 23, 2002 | 06:17 PM
96BLUMAX's Avatar
I just got a new transmission and it is all dirty and greasy. Just checking if it needs to be greasy on the inside of the bellhousing before I go ahead and clean it. Any problems with cleaning the inside?
Old Nov 23, 2002 | 06:58 PM
BriGuyMax's Avatar
go ahead and clean it....if it's a manual...but make sure theres still grease on the throw-out bearing...
If it's an auto....I'm not sure
Old Nov 23, 2002 | 08:14 PM
96BLUMAX's Avatar
Yeah it is manual and its really dirty. I guess i'll go ahead and clean it tommorow.
Old Nov 24, 2002 | 06:13 AM
MardiGrasMax's Avatar
Grease is needed on the clutch fork pivot ball/point thingy also.
Old Nov 24, 2002 | 10:08 AM
96BLUMAX's Avatar
Since there are a few things that need grease on the inside, should i only clean the outside? Will the grease affect the performance of the tranny at all on the inside?
Old Nov 24, 2002 | 11:09 AM
Clean it all and really good, and put fresh grease back on these two spots.
Old Nov 24, 2002 | 11:10 AM
96BLUMAX's Avatar
What type of grease?
Old Nov 24, 2002 | 11:12 AM
Thick high pressure grease, like what is used in CV joints.
Old Nov 24, 2002 | 11:34 AM
njmaxseltd's Avatar
High temp! It gets hot in there.
Old Nov 24, 2002 | 11:13 PM
BriGuyMax's Avatar
that's the throw-out-bearing
Old Nov 25, 2002 | 05:18 AM
Not exactlly, the TOB sits on the output shaft sleve. I am talking about the fork that moves it, it has a pivot ball that needs greese also.
Old Nov 25, 2002 | 06:11 AM
turbo97SE's Avatar
When cleaning, I found that brake cleaner is awesome on the dirt though not 100% necessary. Do not use a blow gun! Don't know about nowadays, but they used to use asbestos on the clutch lining like brake pads.
Old Nov 25, 2002 | 06:14 AM
96BLUMAX's Avatar
Thanks, I'll try the brake cleaner. It was hard to clean with paint thinner.
Old Nov 25, 2002 | 09:26 AM
BriGuyMax's Avatar
ok...now I see what you're talking about. I forgot about that part. When you said "thingy" it threw me off.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
