Max is surging?? Any suggestions what it could be?
Old Nov 26, 2002 | 05:00 AM
redmaxpa007's Avatar
i SeE what you did therE
my friend has a 96 with 100k miles and had a tune up recently.
he noticed the surging very faintly when he bought the car months ago..
no one really felt it and said he was
i was in the car last week and i did feel it. we were accecerating up a on ramp to the high way.
he called me over the weekend as said he took a trip to philly (2 hours each way) and it was worse now.
any suggestions.. i know there is hardly any info..
Old Nov 26, 2002 | 05:04 AM
AntGVR4's Avatar
What is surging ?
Ant
Old Nov 26, 2002 | 05:07 AM
Originally posted by AntGVR4
What is surging ?
Ant
the whole car it feels like it wants to accerate more but then holds back..
Sprint's Avatar
cleaning the throttle body is a start... the throttle plate might be sticking open.. and that maybe what is causing the surge
Old Nov 26, 2002 | 05:28 AM
AntGVR4's Avatar
You said he recently had a tuneup.
Were the plugs gap checked before installation?
Also I'd check the ignition, even though maxima is coil on plug I'd check to make sure all the coils are making good contact with the plugs and that the wires going to the coils aren't damaged.
Does the car shake a little at idle or you only encoutner a problem under acceleration?
Has his miles per gallon of gas changed since it started happening?
Ant
Old Nov 26, 2002 | 05:34 AM
Sonic's Avatar
I'm thinking either a coil/contact problem, or a dying/clogged fuel pump.
Old Nov 26, 2002 | 05:39 AM
njmaxseltd's Avatar
Chech the ECU for codes. Bet the KS is causing the timing to retard, there's your loss of power.
Old Nov 26, 2002 | 05:46 AM
Sonic's Avatar
But there isn't any surging when the KS goes bad, the car just gets a bit slower.
Old Nov 26, 2002 | 07:46 AM
kramerica72's Avatar
Maybe a bad throttle position sensor or air flow meter? I have seen the TPS go bad on a lot of cars without throwing a code.
Old Nov 26, 2002 | 10:21 AM
dwapenyi's Avatar
I bet his feul filter hasn't been changed in a looooong time.
DW
Old Nov 26, 2002 | 10:41 AM
DanNY's Avatar
Ad·min·is·tra·tor
DW
:cough: tune up recently :cough:
Old Nov 26, 2002 | 10:49 AM
dwapenyi's Avatar
Still . . . . . .
DW
Old Nov 26, 2002 | 11:09 AM
njmaxseltd's Avatar
If the KS output swigs back and forth, ping/no ping condition, his timing will be constantly moving. You'll feel this as a loss in power, then a surg of power as the ECU constantly adjusts timing.
Old Nov 27, 2002 | 04:29 AM
thanks for all the advice and possibe causes..
Old Apr 9, 2008 | 07:31 PM
801maxima's Avatar
ive got the same prob but it doesn't show any codes and the surggeing get is intermittant and it has a rough idle sometimes
Old Apr 15, 2008 | 03:37 PM
Trashman's Avatar
My piece of crap 99 shakes when idling, sitting at a stop light, in neutral, in gear, dies going around corners. Any ideas? Just replaced the last of the 6 expensive coil packs today, all new plugs also. No codes at all. Ready to push it off a damn cliff.
Old Apr 15, 2008 | 05:14 PM
99BlackMaxMS's Avatar
Guys, read the last post date.....
11-27-02
Old Apr 15, 2008 | 06:38 PM
Trashman's Avatar
just trying to get enough posts so I can start a thread and find out whats wrong with this piece of crap.
Old Oct 3, 2009 | 05:53 PM
gpresar's Avatar
This thread is a good example of why it would be so useful for the original posters to reply with the fix that ended up solving the problem. It is frustrating to see someone describe the symptoms you have without taking the time to post a solution!!!
captchaos
Mar 15, 2016 12:18 PM
RWCreative
Sep 21, 2015 11:01 AM
lrb6805
Sep 17, 2015 04:49 PM
ik95
Sep 16, 2015 08:11 PM
MaxLife17
Sep 8, 2015 02:36 PM
