RPM Switch
Old Dec 1, 2002 | 09:15 AM
SuDZ's Avatar
RPM Switch
Okay, since I dont want to take apart the dash to get to the tach for input on the RPM switch I am going to get it from the coil pack.
Does it matter which plug I get it from?
SuDZ
Old Dec 1, 2002 | 09:32 AM
1MAX2NV's Avatar
Re: RPM Switch
Nope.
SuDZ
Old Dec 1, 2002 | 09:34 AM
SuDZ's Avatar
Re: Re: RPM Switch
Originally posted by 1MAX2NV
Nope.
Thanks.
SuDZ
Old Dec 1, 2002 | 09:46 AM
SuDZ's Avatar
Ok here is another thought, since everyone was having problems with the relay and just taking it out, how are you wiring it now? Basicly the same but instead of the RPM switch or the solenoid going to the relay then power, just directly connect it to power?
SuDZ
Old Dec 1, 2002 | 11:08 AM
MAXINXS's Avatar
SuDZ
I am not using a relay. Instead I am running a 1.0 fuse from the + battery to the Harlan switch.
Harlan RPM switch
black wire = ground
red wire = + battery
- also hook up power wire from solenoid to this.
other wire from rpm switch = tach signal
Black wire from rpm switch (seperate from the 3 joined wires) ground to solenoid. That is all.
gavin68
Sep 18, 2021 12:36 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
lrb6805
Sep 24, 2015 05:03 PM
