What kind of brake fluid to use?
On my way out this morning my dash brake light stayed on my whole commute. I believe it is due to my brake fluid level being low. What kind of brake fluid do you guys use on your cars? I would like to try not to buy from the dealer due to higher cost. Also my car is still under factory warranty, do you think I should have them check it out first?
Re: What kind of brake fluid to use?
off the shelf..Castrol LMA brake fluid.
someone more exotic ATE blue/gold.
Check the fluid 1st..if u topped it off and still a light...go get it checked. also might be LOW on brakes...have them looked at.
Re: Re: What kind of brake fluid to use?
Originally posted by seximagtr
umm dash brake light? Sounds like someone forgot to release the emergency brake?
Re: Re: Re: What kind of brake fluid to use?
Actually i checked that right when i was pulling out of my driveway...so thats not the case.
Adam,
your pads are probably near worn out...when the pads wear the caliper piston is able to push further, therefore making more room for fluid in the lines rather than in the brake fluid tank where the fluid level is measured. DON'T ADD FLUID...it will just overflow and get everywhere when you do change your pads.
Originally posted by BriGuyMax
Adam,
Adam,
Probably good time for a complete brake fluid flush too.
http://forums.maxima.org/showthread....essure+bleeder
Originally posted by Nealoc187
Ford Motorcraft Heavy Duty High Performance DOT 3/4. It has a dry boiling point as high as Motul brake fluid, and is el cheapo.
Adam,
Adam,
Need help
23
Oct 2, 2015 08:56 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
