Which O2 sensor do you tap for a a/f guage??
Old Dec 10, 2002 | 10:04 AM
Battle Max
Sup im having a a/f guage installed and i was wondering which o2 sensor is the common one to tap into?? i did use the search function and couldnt come up with anything conclusive.
thanks
Jon
Old Dec 10, 2002 | 10:08 AM
funnylittlman's Avatar
I'll tell you when I install mine in a couple days
We'll find out!
Old Dec 10, 2002 | 10:24 AM
The_Bomb's Avatar
Re: Which O2 sensor do you tap for a a/f guage??
thanks
Jon
Either front O2 sensor. They are wires 50 or 51 on the ECU if you want to keep it inside of the car.
Adam
Old Dec 10, 2002 | 10:46 AM
Sprint's Avatar
http://forums.maxima.org/showthread....130#post281130
http://forums.maxima.org/showthread....541#post281541
Old Dec 10, 2002 | 10:58 AM
Aaron's Avatar
Langley AFB Sux
Sprint........how did you get that info? tsk tsk.......
Old Dec 10, 2002 | 11:44 AM
Sprint's Avatar
Old Dec 10, 2002 | 12:24 PM
mayhem_J30's Avatar
...so are you just gonna monitor one half of your motor?
Old Dec 10, 2002 | 12:30 PM
Sprint's Avatar
to have an effective A/F gauge you should buy a separate O2 sensor for it.. other wise its just a bunch of blinking lights going up and down.. not really doing much and not accurate.. you r better off buying an EGT Gauge
Old Dec 10, 2002 | 01:18 PM
EZEMaxima's Avatar
So Sprintmax, how about the rear O2 sensor? If not then where would you recommend install the separate O2 sensor.
I have an Apexi turbo timer and i hooked up the A/F sensor wire to the rear O2 sensor.
Old Dec 10, 2002 | 01:26 PM
I thought tha the rear one is the "dummy" sensor, and doesn't really do much...?
Old Dec 10, 2002 | 03:49 PM
Chebosto's Avatar
RIceD OuT moDErAtor
wth?
rear?
nooo.
the rear does nothing.
only the front two tell the ECU the amount to alter fuel/air with.
if anything, you should be installing a wide band o2 sensor to help you with your turbo timer....
redoit.
Old Dec 10, 2002 | 06:09 PM
tampamax's Avatar
Sorry for being the idiot here but EGT guage? where? why?
And where should your "seperate" O2 sensor go?
Old Dec 10, 2002 | 08:04 PM
Sprint's Avatar
Exhaust Tempreture Gauge.. it measures the Exhaust tempreture..
as Cheston said above a wide band O2 sensor would be great because it will give more accurate readings.. the 02 sensor of the car is connected to so much **** on the car its really ver inaccurate
Old Dec 11, 2002 | 03:38 AM
EZEMaxima's Avatar
So where do you recommend installing the wide band O2 sensor? Before the cat??? I have a Stillen Y-pipe and there is a hole that is plugged on the lower front half but i'm not sure it will accept a O2 sensor.
Old Dec 11, 2002 | 03:59 AM
redmaxpa007's Avatar
i SeE what you did therE
if you have a hole plugged in your y pipe then it is is for an 02 sensor.
and yes, before the cat...
Old Dec 11, 2002 | 06:32 PM
EZEMaxima's Avatar
So what does the rear O2 sensor is there for. If i disconnect it, my CHECK ENGINE light comes on.
Any brand you guys can recommend for the wide band O2 sensor. I'll be checking if an O2 sensor fits into the hole this weekend.
Old Dec 11, 2002 | 06:55 PM
tampamax's Avatar
Thanks for inlightning me without blasting me for not knowing.
Next ?, how stable should the a/f guage be if it is hooked up properly? Mine bounces back and forth all the time, probably a couple times a second, until I go to wot; then it stays rich until I let up. Should it be more stable than that? Bought the car with the guage already hooked up. Just asking cause I want to make sure to take care of the car and I want everything to be done right.
Old Dec 12, 2002 | 07:16 AM
Supposedly that's normal....
Old Dec 12, 2002 | 07:31 AM
Sprint's Avatar
yeah due to the fact it doesn't have its own separate O2 sensor.. its just a bunch of fancy lights..
Old Dec 12, 2002 | 08:54 AM
tampamax's Avatar
So if you hook up a separate O2 sensor will the guage lights not bounce around? If it does then how much difference will it be between what I have now, if any? Also was told that running leaded race fuel will "corrupt" or ruin the O2 sensors. What would be the reason for that? Is there a way to run the race fuel safely(double negative-I know) without swapping them out for extremely expensive ones?
Old Dec 12, 2002 | 09:17 AM
Sprint's Avatar
i am not sure.. because i havn't really done it.. but most of the guys that have done it have like 200 - 300 A/F gauges.. like Y2KevSE, MardigrasMax and sx7r..
i have run race fuel at the track
but i wouldn't run it unless you are running Nitrous or Turbo/Supercharged
my03maxima
Jul 28, 2024 07:40 AM
Miket2006
Mar 1, 2021 03:55 AM
