Help me solve my exhaust problems..
i hit something on the road about a month ago and off an on my exhaust rattles pretty bad. sounds like its gonna fall off or something.
i noticed there is a little metal beam/bar near the front of the Bpipe and after the Cat.
i think that's one of the culprits of the rattling.
is that piece really necessary? im thinking of just taking it off and let it free roam (the bpipe).. i know its there to prevent the exhaust coming down too far but im 85% sure thats the cause of the rattling noise.
second problem is. that after i hit that block of whatever (i couldnt move. it was fast lane in the rain all lanes full) my car also got LOUDER. i noticed a dent on my RT cat, you think its possible it cracked the ceramic?
aiya.....
--ches
aiya.....
--ches
I had a piece of the brick come loose in my RT cat. It would rattle at certain rpms. I took it off and you could see the 1/2 of the brick slide back and forth. The exhaust shop said a old 02 sensor heated the cat up too much and caused the brick to come loose. I didn't hit anything with it.
you can remove that cross-member or try and place some washers in between the cross-member and where it mounts... this may give you some extra clearance. I know a few people needed to do this after getting y-pipes since they banged against that bar.
Jeffy: Hmm... did you remove the brick? Funny thing was i got a check engine lite a few days later. Right bank 02, and knock sensor. i cleared it and waited for it to return. nothing... back yet. so maybe it was a fluke?
i can orientate the noise coming from underneath my shifter (for sure)..
UMD: thanks. but you dont forsee any problems removing that cross member. eh? perhaps i shall bend it down into more of a U shape...
Nope. 1/2(front) half of the cat was still there so I left it for now. I have an used carsound to replace it but I've run into another snag. I threw an rod/crank endcap and it seized my motor. So as you can fathom, the rattlely cat is a relatively minor problem.
SuDZ
Temporarily, removing it shouldn't matter.. just to see if it helps. If it turns out to be a problem, then you can try to get some more clearance.... People have removed it entirely without issues tho....
.. i onlyhear the rattle at low rpms when i just start moving.
its like some homeless guy banging on bones to get change.
rumble rumble rumble.
#%@# makes my car look/sound cheap.
i feel embarassed when i drive it.
heheh.
thanks Jeffy.
i give you:
$20!
heheh.
thanks Jeffy.
i give you:
$20!
Re: Help me solve my exhaust problems..
I replaced the hanger at that location and the rattling went away but in the mean time I bent that piece down a bit..
aiya.....
--ches
aiya.....
--ches
When I got my Apex'i WS, my exhaust banged when I went over larger bumps. I took it to the exhaust shop, and they replaced the hanger w/ a more heavy duty one for the B - Pipe. The pipe still hits that beam below the B pipe.
I would go w/ Redmax's idea, and see if the ceramic didn't get f'ed up.
Chebosto maybe that beam got bent upwards a bit?? just trying to imagine how a block could bend that bar, or even loosen some bolts???
I took that cross memeber/brace that you're talking about off the day I did my exhaust install and never put it back. No ill effects.
I had a RT cat, and one day I just lost all my power. Came to find out that the bricks insided the cat shattered, left the cat, and clogged the b-pipe. Ever since I've had a test pipe and no problems.
interesting.. i guess i better check it out and fix it soon.
It's almost like a plague of disease that everybody has to try it themselves in order to believe it (including myself)
Carsound???
I've had this cat for over two & half years.
Originally posted by MaxTuner
I thought it's been discussed million times that RT Cat sucks????
Carsound???
Carsound???
