www.NitrousMini.com a joke?
Old Dec 19, 2002 | 01:35 PM
  #41
RussMaxManiac
Re: Russ I got 4-words for ya!
Originally posted by IceY2K1
FACTORY FUEL PRESSURE REGULATOR
Russ you are wrong. I don't feel like arguing anymore.
Really, and the ECU again adjusts to keep the MIXTURE right.
Still waiting for you to prove me wrong.
Hook up a consult to your OBD2 port and watch teh ECU readings when you spray on a dyno too.
Old Dec 19, 2002 | 01:37 PM
  #42
deezo's Avatar
Oh boy................
  #43
Shadow's Avatar
Re: Re: Re: Re: Re: Actually, you are correct! I wasn't, however....
OK, so by your logic, I can pull the Vortech FMU off of my SC setup because the ECU will compensate. Why even bother sending one in the first place right?
Your ECU will compensate for closed loop operation, part throttle stuff. But at wide open throttle, your ECU is programmed with the fuel maps and everything. Nothing changes that unless you get a new chip. For little stuff like headers and intakes, there is enough headroom that you're not running lean.
But when you're talking about a 50 shot or higher, then you need to up the fuel pressure or add more fuel another way. It's that simple.
And I've installed nitrous kits, so I'm not just making up stuff here.
Originally posted by RussMaxManiac
Until you have installed NOS systems and know how they work, please don't post the BS anymore. Your info is false. Someone who knows NOS here needs to post, not people who do not even have it.
Really, All other kits do not come with a fuel pressure regulator, so how do they increase the FUEL? HMMm, ECU does it. lol! Your factory conditions CHANGE when you do things to your car. You have a threshold of space you can move in. Ever since I put the headers on my car, it has become very RICH running. WOW! the ECU readjusted it self. But wait, it can't per what you say. lol
Old Dec 19, 2002 | 01:41 PM
  #44
RussMaxManiac
The stock FPR adjusts for the fuel, but the ECU still controls the MIXTURE. It changes within a millisecond to correct it when the NOS is activated. WHY the hell do you think JWT has ECU modules that connect onto a stock ECU to help it adjust MORE than factory defaults. Factory defaults can only adjust so far. That is why 50-75shot kits are safe with a stock car. SX7R can do it whatever way he wants. Don rusn 12.2 off nos, and he never HAS blown a engine like SX7R has and another person in Dallas. I shall not go there.
There are many types of kits you can install and different ways. Direct Port, to dry kits right in the intake plumbing. The correct way is to have the MAF read the info FIRST before letting it go into the engine. Your asking for trouble the other way.
Originally posted by Shadow
Um, Russ, it's not the ECU that's doing it. It's the fuel pressure riser.
My NOS kit came with a regulator (not really a regulator, but it taps into the factory fuel pressure regulator and increases the pressure) as do all others. What do you think the fuel bypass is for? It taps into the vacuum line of your fuel system. that's why there are 2 solenoids with the NOS kit and a fuel pressure safety switch. If it were the ECU controlling things, would you need to increase fuel pressure?
If you're not supposed to spray after the MAF, how come Thomas (SX7R) did it? He doesn't know anything about nitrous? How come just about every other person on this board sprays after the MAF? How come Matt sprays after the MAF? Why does NOS give you instructions on how to tap into your freaking throttle body (which of course is after the MAF) if you're not supposed to do it.
And I've installed 3 nitrous kits, 2 NOS and 1 NX.
Old Dec 19, 2002 | 01:45 PM
  #45
RussMaxManiac
Re: Re: Re: Re: Re: Re: Actually, you are correct! I wasn't, however....
Hmmm from se-r.net:
Here is the dyno chart of Project SE-R with JWT's 100hp NOS.
This is JWT's ECU controled automatic NOS system that uses only a single fan jet and solenoid. The JWT system uses a seperate independant daughterboard and E-Prom to control engine functions under NOS operation. When the system is enabled the ECU looks at CAS signal, TPS and MAF voltage. When WOT @ 4000 rpm is detected the ECU will automaticaly turn on the NOS solenoid and kick the injectors up to a higher duty cycle to provide inrichment. The ECU will also retard the spark. The factory rev limiter is maintaned by the ECU. This makes for a pretty safe system.
Due to it simplicity, it is also the easyest system to install. The stock injectors can be used for up to a 50 shot. For more than that, bigger injectors from a 94 or later turbo Z or Q45 must be used.
Why do you think they mention MAF voltage? Because the jets are before the maf to get the correct reading. THE CORRECT WAY to install a kit.
Old Dec 19, 2002 | 01:51 PM
  #46
Shadow's Avatar
OK Russ, whatever you say. Since you've found a way to change the open loop mode without a new chip, you know a lot more than I do. And thank you for showing me that a stock Maxima can't handle more than a 50-75 shot without a new ECU.
I've installed a direct port kit, I know how they work. Would you please explain to me how they get away with adding nitrous and fuel after the MAF? Wouldn't the poor ECU be too confused to work any more?
BTW, look at the JWT site. The picture they show of their nitrous kit has the nozzle spraying after the MAF on the 300ZX they feature. Give them a call and explain to them what you've explained to me so they see the error of their ways too.
  #47
mzmtg's Avatar
Minister of Silly Walks
Pssst... Russ...
The NOS website says you're wrong. According to this page:
http://www.holley.com/HiOctn/TechSer.../NOSTech1.html
The extra fuel is delivered by increasing fuel pressure when the system is activated. The ECU has no control over fuel pressure.
Old Dec 19, 2002 | 01:53 PM
  #48
athlon omega's Avatar
I originally posted the first thread about the nitrousmini system. However, I wonder if the person that just bought it off of ebay is a member of maxima.org.
Old Dec 19, 2002 | 01:55 PM
  #49
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
I'm STILL not getting involved, but to answer your smoke-screen.
JWT has ECU modules that COMPENSATE, ie add extra fuel, by increasing the injector pulse width, so you don't need to go with SKY HIGH fuel pressure.
The raising of Fuel Pressure is why DRY kits max out at 100+hp, where as WET kits can go much MUCH higher since they don't need to raise fuel pressure(as long as the FP can support), ON STOCK FUEL SYSTEMS.
You can only run so much fuel pressure on stock fuel injectors/rails before you go static. With LARGER injectors and an ECU to control them at idle(ie JWT systems), you don't need to INCREASE fuel pressure to get extra fuel.
Old Dec 19, 2002 | 02:09 PM
  #50
Wait a minute. Those nitrous mini systems guys are acting shady. When I went to their website the other day. The price was like $99. Now it's $210! Did demand just suddenly skyrocket?
Old Dec 19, 2002 | 02:12 PM
  #51
deezo's Avatar
Yeah, to some unsuspecting ricer.
Old Dec 19, 2002 | 02:27 PM
  #52
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Old Dec 19, 2002 | 03:00 PM
  #53
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
you're just mad cause you're loosing the Ebay auction, no Mini NOS for joo!!
Originally posted by Chris91SE
Old Dec 19, 2002 | 03:04 PM
  #54
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Old Dec 19, 2002 | 03:37 PM
  #55
Sprint's Avatar
checking in....
Old Dec 19, 2002 | 03:42 PM
  #56
Sprint's Avatar
since 3 people are telling russ he is wrong..
i think its time for.. um..
Old Dec 19, 2002 | 03:45 PM
  #57
Sprint's Avatar
if i know russ.. he is basing his information off someone elses setup.. if my guess is correct.. he is basing this off Don's Nitrous Setup with JWT Daughter Board and NOS controller.. if i also know russ.. he is calling, faxing, emailing.. sending morse code for Don to come and prove you guys wrong..
until then.. lets just sit back and wait
Old Dec 19, 2002 | 03:46 PM
  #58
Sprint's Avatar
awww fck it.. why not 4 in a row..
Old Dec 19, 2002 | 03:52 PM
  #59
IceY2K1's Avatar
About time JoO showed up!!!
Yes, I have a feeling Russ is collecting his ammunition, but since he's CLEARLY mistaken, he may be gone awhile.
to me! to me.
Just playing Russ.
Old Dec 19, 2002 | 03:55 PM
  #60
Sprint's Avatar
Re: About time JoO showed up!!!
to me! :birthday to me.
Just playing Russ.
i was on the train when i got your email i am home now
I could spew my 1 1/2 years of Nitrous Knowledge in this thread.. but then it would like..
a) i was telling Russ he is wrong because i am picking on him.. (yes he is wrong)
b) i didn't know what i was talking about
c) repeating everything you, jeff and ben already said
Old Dec 19, 2002 | 03:57 PM
  #61
IceY2K1's Avatar
Re: Re: About time JoO showed up!!!
Old Dec 19, 2002 | 03:59 PM
  #62
mzmtg's Avatar
to me! to me.
Just playing Russ.
He does tend to just run away when the evidence against his ranting starts to pile too high...
Old Dec 19, 2002 | 04:03 PM
  #63
Sprint's Avatar
oh he will be back.. ither with more BS.. or someone to prove his point.. in a nice lenghty post
Old Dec 19, 2002 | 04:16 PM
  #64
RussMaxManiac
to me! to me.
Just playing Russ.
Well, I don't believe I was 100% wrong, but I was somewhat wrong. Hmmm, obviosly even after installing a few NOS systems and learning from others, I don't know everything there is to know about NOS. But still, this kit I was talking about for the money is still a good investment for some cheap, reliable hp as long as the SHOT isn't that big.
No, I didn't go to Don Sprint.
  #65
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Old Dec 19, 2002 | 04:23 PM
  #66
IceY2K1's Avatar
Very well said, Russ.
I'm so PROUD!
Next time I tell you NICELY that you are wrong, pleeease don't take offense. You know your shiiit, but we all *** the pooch every now and then.
JooO need to just admit when wrong ONCE in awhile or the hounds get thristy for blood.
It's been fun. Later!
Old Dec 19, 2002 | 04:32 PM
  #67
Sprint's Avatar
oh ****.. the world is coming to an end..
Old Dec 19, 2002 | 06:27 PM
  #68
96BLUMAX's Avatar
yeah this is very old. I posted this last week.
Old Dec 19, 2002 | 08:31 PM
  #69
IceY2K1's Avatar
Last week is "very old"?
Old Dec 20, 2002 | 07:08 AM
  #70
1MAX2NV's Avatar
OMG!!!! Who let Russ install their nitrous kit?? This thread is too funny.
Old Dec 20, 2002 | 07:17 AM
  #71
1MAX2NV's Avatar
Russ is probably talking about how Don's kit works. The way that system works is by no mean is the same as other dry manifold kit.
Old Dec 20, 2002 | 07:32 AM
  #72
DanNY's Avatar
Ad·min·is·tra·tor
stubborn
1. u refused to believe you were wrong even after numerous members told u so.
2. u refused to believe actual information and took your "friend's" install as the benchmark.
3. even after everyone proved u wrong u still won't admit that you're fully wrong...just partially wrong..hey buddy if you're wrong..you're WRONG!
4. the fact that you do not know how to correctly install nitrous kit on someone's car is quite scary.
5. DO NOT EVER COME CLOSE TO MY CAR OR I'LL SHOOT TO KILL.
so russ time to do a recall on your install job and drill another hole infront of the MAF?
Old Dec 20, 2002 | 07:45 AM
  #73
RussMaxManiac
Re: Re: Re: About time JoO showed up!!!
Now your telling me I don't know how to install a NOS kit on a car? lol!
I have installed 4, none of them have had problems. I must be doing something right. lol!
Originally posted by DanNY
stubborn
Old Dec 20, 2002 | 08:05 AM
  #74
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Re: About time JoO showed up!!!
well you're doing partially right...not 100% wrong.
Old Dec 20, 2002 | 08:14 AM
  #75
RussMaxManiac
Re: Re: Re: Re: Re: About time JoO showed up!!!
Lets see here..
99 Camaro z28, Been installed for 3 yrs. Installed before the throttle body, only place we could put it on his, no problems. He runs 100 shot, 550 hp to the wheels on spray. My first install actually.
01 VR6, before the maf, stock air box, no problems.
Altima Auto 00, Before maf, in cone filter pipe, no problems, runs
14s.
95 Camaro V6, before maf, no problems.
Old Dec 20, 2002 | 08:27 AM
  #76
mzmtg's Avatar
Your not supoose to spray after the MAF. Your asking for trouble.
That statement seems 100% wrong to me. You can put the nozzle wherever you want as long as it's before the TB.
Old Dec 20, 2002 | 08:30 AM
  #77
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Re: Re: Re: About time JoO showed up!!!
Lets see here..
14s.
someone insert cookie pic.
does that make u a professional nitrous installer? no
does that mean it's installed correctly? maybe
but the members proved that you did in fact installed them incorrectly..do not justify to me/us that since the car is running ok that it's installed correctly.
you'll never shut up until someone proves u wrong. like i said partially wrong or not..you were wrong...be a man and admit that.
Old Dec 20, 2002 | 08:44 AM
  #78
RussMaxManiac
Re: Re: Re: Re: Re: Re: Re: About time JoO showed up!!!
Nah, its okay. I listen to people with YEARS of experience before others. Don has years of experience, Mike Kojima has ALOT more experience with Nissnas overall. He puts it before the MAF on Se-rs and that is whats recommended over there. MUST be a reason for that.
But to you guys eyes I am 100% wrong when I am not. You can do it either way, whatever pleases you. I rather have the ECU notice all the sensors changing than JUST ONE. It's safer.
Old Dec 20, 2002 | 09:11 AM
  #79
mzmtg's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: About time JoO showed up!!!
What sensors does the ECU "notice" when in open-loop mode? It's does not continuously adjust the A/F ratio at WOT.
Old Dec 20, 2002 | 09:46 AM
  #80
IceY2K1's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: About time JoO showed up!!!
Ben, put this thread out of it's(MY) misery pleeease!
Samurai lock hai!
