Car shuts down when I break.. sometimes
Old Dec 22, 2002 | 10:48 PM
Sexima's Avatar
I have no idea why my car does this...
but when I break and rpm goes low, it goes lower.. lower.. light dims and shuts down.. happened on high ways and roads and on and on... it's getting worse... What's happening~?~?~?~?~?~?
Old Dec 23, 2002 | 05:22 AM
njmaxseltd's Avatar
Girlfriend, you got something going on with your throttle body. It could be the IACV sticking or just a dirty throttle body. If you clean both of them and it still does it, start looking at the MAF.
Tom
Old Dec 23, 2002 | 08:41 AM
njmaxseltd's Avatar
Originally posted by TonyBmax
Push the clutch in.
Old Dec 23, 2002 | 08:49 AM
emax02's Avatar
MAFS
Old Dec 23, 2002 | 08:52 AM
voltman's Avatar
When you break what?
Old Dec 23, 2002 | 09:10 AM
deathwish's Avatar
Re: Car shuts down when I break.. sometimes
I'd vote for something with the MAF too. Also check the hoses going to the intake post MAF, I had one of them come loose one time and this happened.
Old Dec 23, 2002 | 11:06 AM
hockeyghst's Avatar
i had this problem about 2 months ago....i had a bad battery and when i would step on my brake the car died on me......???this might help.....thats what the problem was for me...
Old Dec 23, 2002 | 02:31 PM
Lime's Avatar
whelp, if your alternator isn't charging your battery enough, then when you brake, the excess electricity going to the brake lights and power braking could push your car to die. Check your battery reading before anything else, to rule this out.
Old Dec 23, 2002 | 03:04 PM
white95max's Avatar
If your car is a 5-speed, you need to push the clutch in when you are braking if the RPM's are less than 1000 or so. If it's not a 5-spd, then I would suspect your battery also.
Old Dec 23, 2002 | 03:17 PM
nadir_s's Avatar
vicodin ... gift of life
it's amazing on a car forum, how many ppl can't spell the word BRAKE
Old Dec 23, 2002 | 08:55 PM
† ErV †
so... they also don't seem to know that 'your' and 'you are' are two different things. let's just send them to grammar school eh
Old Dec 23, 2002 | 09:08 PM
Conrad283's Avatar
I need a truck
who kares abut grammer?
Old Dec 23, 2002 | 09:12 PM
nadir_s's Avatar
what a no0b-ish response. And how is this off-topic? Hopefully now ppl who read this thread will learn that the word "brake" is spelled b-r-a-k-e, so that the next time they decide to give information, they won't look like a fool.
Old Dec 23, 2002 | 10:59 PM
† ErV †
dude it was a sarcastic response as in 'it's not only BRAKE they mispell so it's not like it will make a big difference'...
Old Dec 24, 2002 | 05:36 AM
Nealoc187's Avatar
SLOW
Have you done Ben's ECU mod, aka cutting the tranny speed sensor wire on your GXE? If so, this could be the culprit, I noticed that when I have my speed sensor disconnected (it's on a switch) my car does the same thing.
I think it's a vacuum thing, and when you apply the brakes there isn't enough manifold vacuum to work the brakes and keep the car running sometimes, it's a very direct correlation, it happens every time I flip my governor switch.
Hondarydr
Dec 30, 2024 06:15 PM
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
erniel
Aug 8, 2015 09:32 AM
