Who has done door inserts?
Old Dec 25, 2002 | 09:05 PM
2kSeattleMax's Avatar
I managed to do the leatherseats.com install within my max. However, I've been driving around with cloth inserts still in my doors (ghetto!). Who has done the door insert installation? Anyone have linkage on an install? The instructions on the leatherseats.com didn't give me a warm and fuzzy feeling. I'm debating on whether or not to have a local upholstery shop do the inserts for me.
Your help is appreciated. Thanks and happy holidays.
Old Dec 25, 2002 | 11:05 PM
Nismo's Avatar
I done mine. go to the group deal section and look for maxed up's group deal and they talk about how they installed them.
Old Dec 26, 2002 | 10:28 AM
gepetto's Avatar
It's actually quite simple (I haven't done it, but I'm recalling the install from memory). You remove the door panel (not the sheet metal, but the interior part) - there are 3 screws one in the handhold and two at the bottom. Remove these screws and then pop off the plastic around the handle. The door panel can then be removed. Lay the insert over the existing one, and press the excess cloth around the insert with a flathead screwdriver. While the panel is off, get some nice speakers up front
The other writeup has good pics etc, but I hope this is a good start.
Old Jan 13, 2003 | 12:11 PM
Anyone know where the writeup is for this (linkage)? The local Katskinz quoted me 175 to do it if I furnished the inserts. This sounds reasonable to me, but am not opposed to doing it myself.
Any help is appreciated.
Old Jan 15, 2003 | 05:47 PM
The inserts I have look alot bigger than the door cloth. I don't want to have to try to trim them.
Old Jan 15, 2003 | 10:29 PM
Nismo's Avatar
They are slightly bigger when you place them over the stock cloth because you need the extra material so you can tuck them into the recessed area around it.
Old Jan 16, 2003 | 08:40 AM
hacim105's Avatar
Yes it's quite easy. It takes a little time. It took me about 45 minutes but that's just cause I was going slow and didn't want to rip the material with the screw driver.
Old Jan 16, 2003 | 08:45 AM
releasedtruth's Avatar
rilla dope
You guys, seattlemax has CFI leather, the pieces of vinyl are much bigger than the insert locations. It needs to be trimmed. I have the exact same setup seattle. I took the fabric off my panels and then..... Left it off. Cleaned off the residue and now my panels are the same color as the gray around it. For now I like it a ton more. You can leave the fabric on I hear, that web spray they sent is pure azz. I tried one, it didn't look perfect. I would pay to have them done myself, no price wouldn't be worth it. Best of luck, I hear contact cement may work better and more smoothly than that spray garbage CFI sent. Those guys suck seriously.... I hope they go under
Old Feb 15, 2003 | 07:30 PM
iansw's Avatar
How are the stock door inserts attached anyway? Glue? Screws?
Old Feb 15, 2003 | 10:15 PM
Nismo's Avatar
stock cloth is glued on to a foam backing which is all glues to the door panel.
stock leather is a seperate panel which is held to the door by these metal prongs.
REDinLV
Aug 15, 2024 12:30 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
lrb6805
Sep 24, 2015 05:03 PM
