0103 code Temp Sensor and 0304 Knock Sensor Helpful Knowledge needed!!!!
I got these codes about a month ago and reset it and last night I got them again. Just wondering what would cause my Temp sensor to go off. The temp gauge stays in the middle range, so I am confused. Also I have never heard my engine knock(allways use premium) and I am not sure why I am getting the knock sensor code. Maybe my sensors are going bad. Any ideas on how to fix this and how much it will cost???
What kinda gas are you running?
-Shing
Originally posted by Shingles
If your knock sensor detects detonation, I believe that the code will pop up.
-Shing
-Shing
Originally posted by got rice?
I'm not too familiar w/ the Max error codes.
103.. is that for the coolant temp sensor, fuel temp sensor, exhaust gas temp sensor, air intake temp sensor.. which temp sensor?
I ALWAYS use Sunoco 94. (and it loves it!)
With my 95 SE, about once a month my knock sensor goes off.
In Canada, that code will not fire off the MIL (malfunction indicator light), and the car runs great.
(Cal cars are different)
I don't know how long it has been doing this, but it has not been a problem.
Keep in mind, if the knock sensor is firing off a code, it DOES NOT MEAN IT IS DETECTING KNOCK, it means the signal received by the ECU was too high, or too low.
kjlouis
Nov 24, 2018 06:09 AM
TonyJr
Aug 20, 2015 12:14 AM
doobadoo
Aug 15, 2015 06:43 PM
