How do "offset" and "backspacing" relate to each other in discussing rims?
Old Jan 7, 2003 | 07:05 AM
phenryiv1's Avatar
Mod her. Ate her.
In RWD circles it is discussed as "backspacing," but here we always talk about "offest." How do the two relate to each other?
Thanks!
Old Jan 7, 2003 | 07:50 AM
1MAX2NV's Avatar
I think this right...
Offset is the measurement between hub mounting surface and center line of the wheel.
Backspacing is the measurement between hub mounting surface and face of the wheel. or maybe it's the measurement between hub mounting surface and the edge of the rim.
Old Jan 7, 2003 | 07:53 AM
1MAX2NV's Avatar
I was close.
Backspacing is "distance between the inboard edge of the wheel and the mounting surface of the wheel"
Backspacing is very important when it comes to clearing big brake kit.
You could have enough offset but limited backspacing due to having a fat lip.
Old Jan 7, 2003 | 07:54 AM
phenryiv1's Avatar
Mod her. Ate her.
Oh yeah, one thing that I remembered...IIRC MORE backspacing sets the rim IN further, LESS backspacing makes it stick out further.
I think...
Old Jan 7, 2003 | 07:59 AM
1MAX2NV's Avatar
Well..the face of the wheel might sit out further when you have more backspacing. The outer "rim" might not change at all.
With backspacing...the greater the number the further the face of the wheel is away from the hub mounting surface.
I think...
Old Jan 7, 2003 | 08:02 AM
1MAX2NV's Avatar
"Rear wheel backspacing is the distance between the inboard edge of the wheel and the mounting surface of the wheel that bolts against the axle hub. It is measured by placing the wheel face down on a flat surface; lay a straight edge across the inboard edge of the wheel, and measure from the wheel mounting surface to the straight edge with a ruler."
Old Jan 7, 2003 | 08:04 AM
1MAX2NV's Avatar
What's "inboard edge"? Sounds like the center of the wheel face? I don't know about you...but I need a damn diagram.
Old Jan 7, 2003 | 08:18 AM
phenryiv1's Avatar
Mod her. Ate her.
I would THINK that inboard edge would be the innermost part of the rim (closest to the center of the vehicle).
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
0m3nc0w
Sep 11, 2015 05:21 PM
