Fuel pressure up after Walbro install
Old Jan 8, 2003 | 12:21 PM
Stephen Max's Avatar
I got one of the Walbro fuel pumps through the recent group deal. After installing it last weekend I noticed that the fuel pressure at idle is at 38-39 psi, up from 34 psi. Pressure at WOT appears to be unchanged at 43 psi, or at most it hits 44 psi.
Anybody else notice this behavior?
My EGT readings appear to be unchanged, about 800F at idle, 1100F cruising at 65 mph, so I guess the ECM is compensating for the additional fuel pressure by shortening the injector pulses. Haven't checked EGT at WOT, but since the pressure is the same as before at WOT, the EGT is certainly the same.
EDIT - I took a closer look at my fuel pressure gauge during a WOT run last night, and it appears I was wrong about the FP being unchanged at WOT - the WOT fuel pressure is at about 50 psi. I didn't run long enough to get a good EGT reading.
Old Jan 8, 2003 | 12:26 PM
Sprint's Avatar
if its the 255 lph.. it goes up.. you gotta use an Aftermark FPR to bring it back down
Old Jan 8, 2003 | 12:30 PM
Is this necessary? I haven't noticed any effect on driveability yet.
Old Jan 8, 2003 | 12:44 PM
Sprint's Avatar
me ither.. but i have the SARD to tune it down a little bit
Old Jan 8, 2003 | 01:02 PM
Jime's Avatar
Re: Fuel pressure up after Walbro install
Your ECM does not check fuel pressure it assumes it to be in the normal 34-43 range, so it will not compensate if its too high. You many notice some difference if fuel mileage with it up that high.
Why did you get the High Pressure pump are you installing nitrous?
Like Sprint said, thats normal for the HP pump and only way to get it down is with aftermarked FPR.
Old Jan 8, 2003 | 01:12 PM
Sprint's Avatar
he has a Supercharger.. i think he might be going smaller pulley and not using the aux pump
Old Jan 8, 2003 | 01:31 PM
Synki's Avatar
That is normal. All you need is a FPR andyou are set.
You aren't running rich enough to damage anything or even foul the plugs.
Old Jan 8, 2003 | 01:35 PM
Dat's right. Going with the 3.25" pulley, if I can ever find the time to do the install.
Old Jan 8, 2003 | 01:36 PM
Jeff92se's Avatar
I'm needing a caw
Are there any fuel pressure regulators that can raise the fuel pressure when on boost. ie.. so I can avoid buying the SARD + Vortech disc type fmu. All in one thingie. I already have the Vortech w/ the 6:1 disc and the Walbro(both not installed though)
Old Jan 8, 2003 | 01:44 PM
mzmtg's Avatar
Minister of Silly Walks
Re: Re: Fuel pressure up after Walbro install
This is true at WOT. However, at part throttle (in closed-loop operation) the ECU will compensate for more pressure by shortening the injector pulsewidth. While it does not read fuel pressure, it will be able to tell what's going on via the O2 sensors.
Old Jan 8, 2003 | 02:05 PM
Jime's Avatar
Re: Re: Re: Fuel pressure up after Walbro install
Geez Ben I want to be right once in a while.
Actually that will help me with a couple of other things I am working out right now. Thanks.
Old Jan 8, 2003 | 02:23 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Actually, that's not 100% accurate, but still true...
According to my OBD-II scans you can also go Open-loop without being at WOT. I believe it happens for a QUICK rate-of-change, ie heavy throttle. For example going from 25% to 75% TPS in a short period of time.
Minor fact I know, but had to throw that in there for know-it-all Ben, since he beat me to it.
Old Jan 8, 2003 | 02:25 PM
mzmtg's Avatar
Re: Actually, that's not 100% accurate, but still true...
I knew that.
Old Jan 8, 2003 | 02:27 PM
IceY2K1's Avatar
Re: Re: Actually, that's not 100% accurate, but still true...
I knew that.
Suuuuuuure....
Old Jan 8, 2003 | 03:39 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Ben Garner is one smart ****.
lowpost99
Oct 26, 2025 06:53 PM
MaxLife17
Jun 27, 2019 01:37 PM
cruce91
Sep 20, 2015 10:23 AM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
